81
I am using Ubuntu on VMWare but I cannot connect to internet because of security restrictions.
I was wondering if there was a way to search for strings through the terminal and find which line the string is located on within the file.
Zanna
  • 72,312
There are almost too many options to list
grep -r 'pattern_to_match' directory_to_search
Will output the file name and full line matching the pattern.
Panther
  • 104,528
36
The best I use is grep command with options -ri (Recursive and case insensitive search):
$ grep -r <text_pattern_to_search> directory_or_path_to_search
options that might be useful to you:
    -i - case insensitive
    -r, --recursive  like --directories=recurse
    -R, --dereference-recursive  likewise, but follow all symlinks
      --include=FILE_PATTERN  search only files that match FILE_PATTERN
      --exclude=FILE_PATTERN  skip files and directories matching FILE_PATTERN
      --exclude-from=FILE   skip files matching any file pattern from FILE
      --exclude-dir=PATTERN  directories that match PATTERN will be skipped.
for deep info you can do grep --help or man grep in linux terminal.
Cheers
xxbinxx
  • 649
10
If you want to find only line number where the sting is located within the file use this:
grep -n '/string_To_Find/=' directory/file_Name
If you want to find line number and also output the full line name where the string is located in the line use this:
grep -n 'string_To_Find' directory/file_Name
And if you only want to find full line name where the string is, use this:
grep -r 'string_To_Find' directory/file_Name
αғsнιη
  • 36,350
