When I booted up my newly installed Ubuntu 11.04, I discovered, to my dismay, that the backlight was off by default. The keyboard shortcut (which is Fn+F6 on my Acer Aspire 4736) for turning on the backlight doesn't seem to work. I have been trying to resolve this problem for the past 2 days now, but with no success. By the way, the backlight did work properly once or twice at random - but the problem again popped up as soon as I restarted my system.
Thanks for your suggestion Lekensteyn, but I tried it and it didn't work. Could you, or anyone else suggest something else? I have really become addicted to Ubuntu, and working on Windows seems unnatural to me now.
Braiam
  • 69,112
Shubham
  • 53
5 Answers5
Here is a solution that worked for me on Ubuntu 11.10 based on http://lare-india.blogspot.com/2011/09/ubuntu-upgrade-caused-blank-screen-on.html
Boot your laptop into Ubuntu.
Connect an external monitor or sit with your back towards a sunny window so the sunlight helps to illuminate the screen (a flashlight can help too).
Press Ctrl+Alt+T to open a terminal and type:
sudo nano /etc/rc.local
You will be prompted for your root password, which was set when you performed the install. Type it in and hit Enter.
Press your down arrow key to move the cursor to the last line and hit Enter
Press your up arrow key once and type:
setpci -s 00:02.0 F4.b=00
Press Ctrl+O to save and Ctrl+X to exit.
Now back in the terminal type:
sudo nano /etc/default/grub
Find the line
GRUB_CMDLINE_LINUX_DEFAULT = "quiet splash"
and edit it to
GRUB_CMDLINE_LINUX_DEFAULT = "quiet splash acpi_osi = Linux"
Back in the terminal enter:
sudo update-grub2
Once it completes, enter:
sudo reboot
Your computer will reboot and when Ubuntu boots back up, you should be able to see the screen with no problems.
Braiam
  • 69,112
Brian
  • 51
I've experienced similar issues with another Acer notebook which was running Ubuntu from a Kubuntu 10.04 32b Live CD (for testing purposes). Before starting up, the backlight was fine. In a later stage, the backlight suddenly turned off.
Luckily, I can remember the commands from my head, so I pressed Ctrl + Alt + F1 to switch to a virtual console. Since I am already logged in on a Live CD I ran:
cat /sys/class/backlight/acpi_video0/max_brightness | sudo tee cat /sys/class/backlight/acpi_video0/brightness
Unfortunately, the backlight turned off again after switching back to the GUI using Ctrl + Alt + F7, so I created a script that should be run in the GUI:
echo 'cat /sys/class/backlight/acpi_video0/max_brightness | sudo tee cat /sys/class/backlight/acpi_video0/brightness' > lite
When switching back to the GUI, I pressed Ctrl + Alt + T to open a Terminal and run:
. lite
Now as long as I stayed in this GUI without switching to a virtual console and back, the backlight would be OK.
Configuring the backlight through /sys/class/backlight/acpi_video0/brightness is a workaround, perhaps there is already a bug report on Launchpad. Otherwise, you could put the above cat .... brightness command in a startup script which will workaround the problem for now.
Lekensteyn
  • 178,446
I have an emachines e725 and every time my screen times out, or computer falls asleep, I have to reboot for it to come back on. The settings for my temporary fixes for /etc/rc.local and /etc/default/grub are below:
1) /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
setpci -s 00:02.0 F4.B=00
exit 0
2) /etc/default/grub
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux"
GRUB_CMDLINE_LINUX=""
I've a solution. When this problem occurred to my HP laptop, I just turn on the emergency light (or torch) in front of the LCD, then everything was visible. Then I go to System Settings, in the Brightness option, I just increased the brightness seek-bar, then my LCD back-light worked, and every problem was solved, then save this setting.
Peachy
  • 7,235
  • 40
  • 47
if the above didn't work, use the same steps, except where it says to edit Grub put: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
Worked for me, on HP 2000 Notebook PC
anon
