My problem on 12.04lts is that somehow my libssl1.0.0 got upgraded to 1.0.1-4Ubuntu5.17 and my libssl-dev requires 1.0.1-4Ubuntu5.14 apt won't update libssl-dev because libssl1.0.0 was upgraded first.
xxx@xxx:~/debian$ sudo apt-get install libssl-dev
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
libtommath0
Use 'apt-get autoremove' to remove them.
The following packages will be upgraded:
libssl-dev
1 upgraded, 0 newly installed, 0 to remove and 123 not upgraded.
1 not fully installed or removed.
Need to get 0 B/1,574 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
dpkg: dependency problems prevent configuration of libssl-dev:
libssl-dev depends on libssl1.0.0 (= 1.0.1-4ubuntu5.14); however:
Version of libssl1.0.0 on system is 1.0.1-4ubuntu5.17.
dpkg: error processing libssl-dev (--configure):
dependency problems - leaving unconfigured
No apport report written because MaxReports is reached already
libssl-dev
Also tried downgrading libssl1.0.0 but got version not found.
xxx@xxx:~/debian$ sudo apt-get install libssl1.0.0=1.0.1-4ubuntu5.14
E: Version '1.0.1-4ubuntu5.14' for 'libssl1.0.0' was not found
Any help would be greatly appreciated.
