I recently upgraded my computer from 12.02 LTS to 14.04 LTS, but experienced problems with launching Google Chrome and being able to use Rhythmbox. Rhythmbox asked if I wanted to install additional software, but the installation failed and returned this error message:
package tex-common 4.04 failed to install/upgrade: ErrorMessage: subprocess
installed post-installation script returned error exit status 1
I found this thread on launchpad about the bug:
https://bugs.launchpad.net/ubuntu/+source/tex-common/+bug/1236951
which offered some suggestions about fixing the error, but the ones I have tried haven't worked for me.
First, I tried these commands (although I think rm /etc/texmf/ didn't work, I got an error message telling me it was a directory). This didn't seem to fix the error.
sudo apt-get remove --purge tex-common texlive-*
sudo rm /etc/texmf/
sudo apt-get install tex-common
sudo apt-get install texlive-base
sudo apt-get install texlive-latex-recommended
I then tried:
sudo apt-get purge tex-common
sudo -E do-release-upgrade -d
sudo -E apt-get -y install tex-common texlive-base texlive-latex-recommended
but again, it didn't seem to fix the problem.
Finally, I tried the last suggestion in the thread:
Uninstall everything to do with emacs and xemacs (I used synaptic package manager, to find what to remove and to completely remove)
I didn't actually do this step because a.) I didn't know if I had any issues with emacs and xemacs, and b.) because I don't know how to use Synaptic to do uninstall only the emacs and xemacs stuff.
Uninstall tex-common and all texlive-* files and:
sudo rm -rf /etc/texmfThis time the command worked, which I assume is because this one removes the files in texmf, instead of the directory itself.
Remove all texlive files (if any) e.g.:
sudo rm -rf /usr/local/texlive/2014 rm -rf ~/.texlive2014Install
emacs24thenauctexusing synaptic package managerInstall
tex-commonusing synaptic package managerAgain, I didn't install
emacs24andauctex, and when it came to installing tex-common, I just tried:sudo apt-get install tex-commonInstall texlive following the instructions on http://tug.org/texlive/ (Installation from dpkg or Ubuntu software centre or synaptic package manager don't work for me.)
Add paths to
/etc/environmentas suggested by the installation program earlier. That is, for the version I installed, to the end of the PATH line add:/usr/local/texlive/2014/bin/x86_64-linuxjust before the closing" and add 2 new linesINFOPATH=":/usr/local/texlive/2014/texmf-dist/doc/info" MANPATH=":/usr/local/texlive/2014/texmf-dist/doc/man"(without the colon, the manpath to everything except tex will be broken)
I think I understood how to do this section, although it's the first time I've ever tried to set a path. Also, based on another thread, I used i386-linux instead of x86_64-linux.
Edit
/etc/manpath.configby adding lineMANPATH_MAP /usr/local/texlive/2014/bin/x86_64-linux /usr/local/texlive/2014/texmf-dist/doc/manafter the last MANPATH_MAP line that already exists.
Originally I wasn't able to edit the manpath.config file as it was read-only, so I had to open the file with sudo vim to edit it.
After going through all of these steps and restarting, the problem is now worse, as I have to go Ubuntu, with Linux 3.13.0-34-generic (recovery mode) for anything to work. Otherwise there will be no icons along the top of the screen (such as battery, network, etc.) and the icons in the toolbar will not respond.
Would anyone be able to help me with this? I don't really know enough about what I'm doing to know if I'm doing something stupid or not.
