I install ubuntu and now my windows can't boot and ubuntu too! ubuntu error message is same to this! and windows error is "A disk read error occurred"
I cant install windows but windows 7 installation disk can't detect my hdd and windows xp's disk show me a "blue screen" and active boot disk can't show my partitions.
I only can run ubuntu live disk and ubuntu detect and show me hdd partitions. but one of my drives can not mount in ubuntu. When i try to open my drive, ubuntu show me this message:
Error mounting: mount exited with exit code 13: ntfs_mst_post_read_fixup: magic: 0x00000000  size: 4096  usa_ofs: 0  usa_count: 65535: Invalid argument
Actual VCN (0x0) of index buffer is different from expected VCN (0x1).
Failed to mount '/dev/sda3': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.
My hdd is not RAID.
I read same questions and find a solution! ntfsfix. But...
When i run ntfsfx:
$ sudo ntfsfix /dev/sda3
Mounting volume... ntfs_mst_post_read_fixup_warn: magic: 0x00000000  size: 4096   usa_ofs: 0  usa_count: 65535: Invalid argument
FAILED
Attempting to correct errors...
Processing $MFT and $MFTMirr...
Reading $MFT... OK
Reading $MFTMirr... OK
Comparing $MFTMirr to $MFT... OK
Processing of $MFT and $MFTMirr completed successfully.
Setting required flags on partition... OK
Going to empty the journal ($LogFile)... OK
Remount failed: Input/output error
p.s. This partition is major for me.
ali
Boot from LiveCD, mount your root partition like this
mount /dev/sda2 /mnt
then do nano /mnt/etc/fstab to add noauto option to this NTFS partition. It should be like ... ntfs defaults,noauto 0 0. Ctrl+X to save, then reboot.
