Can anyone tell me the procedure to install CollabNet Subversion Edge 4.0.10 on Ubuntu 14.04?
I am new to Ubuntu.
Parto
  • 15,647
Here's what I did, step by step:
  1. Installed a "next-next-next" implementation of Ubuntu 14.04 server.
  2. Logged in as root on the console, then ran the following command:
    sudo apt-get install openssh-server
  3. Next we create a non-root user. In this example we are using svnadministrator .
    sudo adduser svnadministrator
  4. (couple of prompts for this procedure, password/user, detail, etc.)
    sudo visudo
  5. Look for---> root ALL=(ALL:ALL) ALL and then below that put in the entry below:
    svnadministrator ALL=(ALL:ALL) ALL
  6. Save your changes.
  7. LOGGED OUT OF ROOT and then log in as the non-root user you created (svnadministrator in this example).
    !!!The notes for subversion says to try and do it as a non-root user, so I did.!!!
    sudo add-apt-repository ppa:webupd8team/java
    sudo apt-get update
  8. (You can change the "6" to "7" or "8" in the next command, depending on the Java version you want. SVN seemed to want 6)
    sudo apt-get install oracle-java6-installer
  9. (Agree to terms.)
    sudo apt-get install oracle-java6-set-default
  10. Set the home variable.
    export JAVA_HOME=/usr/lib/jvm/java-6-oracle/
  11. Get the installer from http://www.collab.net/svnedge. You'll need to login in and/or create an account.
    (I downloaded it to my Windows box then SCP'd it over to my Linux box)
    tar -zxf CollabNetSubversionEdge-1.1.0_linux-x86.tar.gz
  12. The tar.gz file is unpacked to the csvn directory.
    cd csvn
    bin/csvn start
  13. (Wait a minute or so...)
http://192.168.x.x:3343/csvn/login/auth
DONE!
karel
  • 122,292
  • 133
  • 301
  • 332
Dickson
There is a dedicated page hosted by collabnet on this topic.
How ever summarizing the process:
  1. If you have Java installed. Set you JAVA_HOME to point your installation directory. If you don't have java installed then install it first.
  2. Extract your files from archive tar -vzxf CollabNetSubversionEdge<your_version>.tar.gz
  3. Change directory and execute executable csvn/bin/csvn start
Tariq
  • 136
