I am trying to get MrSID support in QGIS 2.4 in Ubuntu 14.04. According to the this tutorial you have to rebuild libgdal against MrSID SDK from LizardTech. But I cannot find the package libgdal-mrsid-src as mentioned in the instructions. However, it appears that this may have been merged into the libgdal-dev package. When I attempt to install this package, I am told that I have to install libmysqlclient-dev but cannot install libmysqlclient-dev since I have MariaDB 10 installed.
Full error message is:
     libmysqlclient-dev : Depends: libmysqlclient18 (= 5.5.38-0ubuntu0.14.04.1) but
 10.0.10+maria-1~saucy is to be installed
    E: Unable to correct problems, you have held broken packages
So here are my original two questions:
  1. Am I correct about the libgdal-mrsid-src package being merged with the libgdal-dev package?
    Answer: Yes but you have to use apt-get source libgdal-dev
  2. If the answer to 1 is yes, then how do I correct conflict and still keep MariaDB 10?
    Answer: This seems to be more of a red herring as I am uncertain that libgdal-dev really needs to be installed. However, if you run apt-get install libgdal-dev libmariadbclient-dev the dependencies appear to be met.
Now I am to the point where I getting unsure of my steps. In the gdal-1.10.1+dfsg directory that is created from installing the sources, I run
./configure --with-gdal=/usr/bin/gdal-config \
            --with-mrsid=/path/to/MrSID_DSDK/Raster_DSDK \
            --with-mrsid_lidar=/path/to/MrSID_DSDK/Lidar_DSDK \
            --with-jp2mrsid=yes --with-geotiff=yes
make
make install
However, this builds the full gdal package and installs it in /usr/local/bin instead of /usr/bin (apt-get install location). This package also does not have mysql support (guess question 2 may not be such a red herring after all). Not to mention, it is not my intention to build the full package from source.
The other option that I tried was to just compile the mrsid plugin for gdal. Stopping the above instructions after the configure command, I changed to the /gdal-1.10.1+dfsg/frmts/mrsid directory and ran make plugin libgdal-mrsid which produced the following error:
/bin/bash /root/gdal-1.10.1+dfsg/libtool --mode=compile --tag=CXX g++ -g -O2 -DHAVE_SSE_AT_COMPILE_TIME  -Wall  -I/root/gdal-1.10.1+dfsg/port -I/root/gdal-1.10.1+dfsg/gcore -I/root/gdal-1.10.1+dfsg/alg -I/root/gdal-1.10.1+dfsg/ogr -I/root/gdal-1.10.1+dfsg/ogr/ogrsf_frmts -DMRSID_J2K  -I/usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include -I../../frmts/gtiff/libgeotiff -DOGR_ENABLED -D_REENTRANT  -I/root/gdal-1.10.1+dfsg/port   -c -o mrsiddataset.o mrsiddataset.cpp
libtool: compile:  g++ -g -O2 -DHAVE_SSE_AT_COMPILE_TIME -Wall -I/root/gdal-1.10.1+dfsg/port -I/root/gdal-1.10.1+dfsg/gcore -I/root/gdal-1.10.1+dfsg/alg -I/root/gdal-1.10.1+dfsg/ogr -I/root/gdal-1.10.1+dfsg/ogr/ogrsf_frmts -DMRSID_J2K -I/usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include -I../../frmts/gtiff/libgeotiff -DOGR_ENABLED -D_REENTRANT -I/root/gdal-1.10.1+dfsg/port -c mrsiddataset.cpp  -fPIC -DPIC -o .libs/mrsiddataset.o
mrsiddataset.cpp: In member function 'virtual CPLErr MrSIDRasterBand::IReadBlock(int, int, void*)':
mrsiddataset.cpp:552:64: warning: 'void* LizardTech::LTISceneBuffer::getTotalBandData(lt_uint16) const' is deprecated (declared at /usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include/lti_sceneBuffer.h:565) [-Wdeprecated-declarations]
     memcpy( pImage, poGDS->poBuffer->getTotalBandData(nBand - 1),
mrsiddataset.cpp: In member function 'virtual CPLErr MrSIDDataset::IRasterIO(GDALRWFlag, int, int, int, int, void*, int, int, GDALDataType, int, int*, int, int, int)':
mrsiddataset.cpp:979:68: warning: 'void* LizardTech::LTISceneBuffer::getTotalBandData(lt_uint16) const' is deprecated (declared at /usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include/lti_sceneBuffer.h:565) [-Wdeprecated-declarations]
                 oLTIBuffer.getTotalBandData( panBandMap[iBand] - 1 );
mrsiddataset.cpp:1017:47: warning: 'void* LizardTech::LTISceneBuffer::getTotalBandData(lt_uint16) const' is deprecated (declared at /usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include/lti_sceneBuffer.h:565) [-Wdeprecated-declarations]
libtool: compile:  g++ -g -O2 -DHAVE_SSE_AT_COMPILE_TIME -Wall -I/root/gdal-1.10.1+dfsg/port -I/root/gdal-1.10.1+dfsg/gcore -I/root/gdal-1.10.1+dfsg/alg -I/root/gdal-1.10.1+dfsg/ogr -I/root/gdal-1.10.1+dfsg/ogr/ogrsf_frmts -DMRSID_J2K -I/usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include -I../../frmts/gtiff/libgeotiff -DOGR_ENABLED -D_REENTRANT -I/root/gdal-1.10.1+dfsg/port -c mrsiddataset.cpp -o mrsiddataset.o >/dev/null 2>&1
/bin/bash /root/gdal-1.10.1+dfsg/libtool --mode=compile --tag=CXX g++ -g -O2 -DHAVE_SSE_AT_COMPILE_TIME  -Wall  -I/root/gdal-1.10.1+dfsg/port -I/root/gdal-1.10.1+dfsg/gcore -I/root/gdal-1.10.1+dfsg/alg -I/root/gdal-1.10.1+dfsg/ogr -I/root/gdal-1.10.1+dfsg/ogr/ogrsf_frmts -DMRSID_J2K  -I/usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include -I../../frmts/gtiff/libgeotiff -DOGR_ENABLED -D_REENTRANT  -I/root/gdal-1.10.1+dfsg/port   -c -o mrsidstream.o mrsidstream.cpp
libtool: compile:  g++ -g -O2 -DHAVE_SSE_AT_COMPILE_TIME -Wall -I/root/gdal-1.10.1+dfsg/port -I/root/gdal-1.10.1+dfsg/gcore -I/root/gdal-1.10.1+dfsg/alg -I/root/gdal-1.10.1+dfsg/ogr -I/root/gdal-1.10.1+dfsg/ogr/ogrsf_frmts -DMRSID_J2K -I/usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include -I../../frmts/gtiff/libgeotiff -DOGR_ENABLED -D_REENTRANT -I/root/gdal-1.10.1+dfsg/port -c mrsidstream.cpp  -fPIC -DPIC -o .libs/mrsidstream.o
libtool: compile:  g++ -g -O2 -DHAVE_SSE_AT_COMPILE_TIME -Wall -I/root/gdal-1.10.1+dfsg/port -I/root/gdal-1.10.1+dfsg/gcore -I/root/gdal-1.10.1+dfsg/alg -I/root/gdal-1.10.1+dfsg/ogr -I/root/gdal-1.10.1+dfsg/ogr/ogrsf_frmts -DMRSID_J2K -I/usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/include -I../../frmts/gtiff/libgeotiff -DOGR_ENABLED -D_REENTRANT -I/root/gdal-1.10.1+dfsg/port -c mrsidstream.cpp -o mrsidstream.o >/dev/null 2>&1
mrsiddataset.o mrsidstream.o  -L/usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/3rd-party/lib -L/usr/share/MrSID_DSDK-9.1.0.4045/Raster_DSDK/lib -lltidsdk -lpthread  -o gdal_MrSID.so
/bin/bash: mrsiddataset.o: command not found
make: *** [gdal_MrSID.so] Error 127
I'm about ready to give up on adding MrSID support, but I can't help but feel that I am close and just need to fix a little step here or there.
RRYontz
  • 19
I believe you are very close. The last line of your output needs the command to create the share library:
g++ -shared followed by the rest of the last line should create your gdal_MrSID.so file.
Aaron Hill
  • 5,035
