I have the following problem: when scaling a window to the bottom of the screen, it gets automatically maximised vertically. This is very annoying as I want to decide how to scale my windows!
I found no option that triggers this.
The compiz plugin grid is disabled. Everything I find when searching for my problem, are references to grid ...
My System:
Ubuntu 14.04.1 LTS
Kernel 3.13.0-32-generic
Compiz 0.9.11.2
Gnome 3.8+4ubuntu3
Using Gnome Fallback Mode
Nicolas
  • 865
Ok, finally found the reason for the automatic window maximising: the compiz resize plugin!
The settings for this plugin contain an option called Maximize Vertically if screen edge hit in the tab General. This did the trick.
Though I checked each compiz plugin within the windows scope a thousand times before, I did not found this checkbox earlier. This is because I searched for a setting of type active screen edge and not of type checkbox.
Compiz resize plugin settings
Note: due to the lack of this information within the compiz plugin settings, I guessed the underlying name of this plugin being resize!
The german localized title is "Fenster skalieren aktivieren" which - directly translated - should be s. th. like "Activate Window Scaling" or "Activate Window Resizing". There is another plugin called "Skalieren" from which I assume, it corresponds to the underlying "scale" plugin, so "resize" should be the right one.
If anyone can confirm or correct this, I will edit my answer.
Update 2016-07-13
The "CompizConfig Einstellungs-Manager" is the "CompizConfig Settings Manager" and used to adjust all parameters of "compiz".
It may not be preinstalled on your system!
Check this by opening a terminal and enter ccsm.
If this command is not found, you can install it with:
sudo apt-get install compizconfig-settings-manager
Note: this install package name was changed somewhen in the past - if you have a really old system it may be named ccsm as well, if I remember this correctly.
Nicolas
  • 865
I find the same setting on my Ubuntu 14.04 and confirm it works too.
Since Nicolas' screenshot is not completely English, here are my steps to find it: CompizConfig Setting Manager-> Window Management -> Resize window -> General (Tab).
For the folks don't have CompizConfig Settings Manager installed, it could be found at: https://apps.ubuntu.com/cat/applications/compizconfig-settings-manager/
Samuel Li
  • 759
You may find conflicts in CCSM between 'Window Management' plugins.
I wanted to stop the window filling the top half of the screen when I took it to the top edge. The behaviour seems to be determined by Grid and Maximumize. I found that even if I unticked: 'Maximumise' 'maximumize to up' and set 'Grid' 'Corners/Edges' 'Top Edge = None' it still half fills the screen when I hit the top edge.
However if I disable the plugin 'Maximumize' it ceases this irritating behaviour.
solar1
  • 31
