On the live-CD session, I tried installing Lubuntu double clicking on the install button on the desktop. Here, the CD starts running but then stops running and nothing happens.
Next, I rebooted and tried installing Lubuntu directly from the boot menu screen using forcepae again. After a while, I receive the following error message:
The installer encountered an unrecoverable error. A desktop session will now be run so that you may investigate the problem or try installing again.
Hitting Enter brings me to the desktop. For what errors should I search? And how?
Thanks for some hints!
On Lubuntu 12.04:
uname -a
Linux humboldt 3.2.0-67-generic #101-Ubuntu SMP Tue Jul 15 17:45:51 UTC 2014 i686 i686 i386 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 12.04.5 LTS
Release:    12.04
Codename:   precise
upowerd appears to hang:
Aug 25 10:53:28 lubuntu kernel: [  367.920272] INFO: task upowerd:3002 blocked for more than 120 seconds.
Aug 25 10:53:28 lubuntu kernel: [  367.920288]       Tainted: G S       C   3.13.0-32-generic #57-Ubuntu
Aug 25 10:53:28 lubuntu kernel: [  367.920294] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 25 10:53:28 lubuntu kernel: [  367.920300] upowerd         D e21f9da0     0  3002      1 0x00000000
Aug 25 10:53:28 lubuntu kernel: [  367.920314]  e21f9dfc 00000086 f5ef7094 e21f9da0 c1050272 c1a8d540 c1920a00 00000000
Aug 25 10:53:28 lubuntu kernel: [  367.920333]  c1a8d540 c1920a00 d9e44da0 f5ef6540 c1129061 00000002 000001c1 0001c37b
Aug 25 10:53:28 lubuntu kernel: [  367.920351]  00000000 00000002 00000000 e2276240 00000000 00000040 c12b0ec5 c19975a8
Aug 25 10:53:28 lubuntu kernel: [  367.920368] Call Trace:
Aug 25 10:53:28 lubuntu kernel: [  367.920389]  [<c1050272>] ? kmap_atomic_prot+0x42/0x100
Aug 25 10:53:28 lubuntu kernel: [  367.920404]  [<c1129061>] ? get_page_from_freelist+0x2a1/0x600
Aug 25 10:53:28 lubuntu kernel: [  367.920417]  [<c12b0ec5>] ? process_measurement+0x65/0x240
Aug 25 10:53:28 lubuntu kernel: [  367.920432]  [<c1654c73>] schedule_preempt_disabled+0x23/0x60
Aug 25 10:53:28 lubuntu kernel: [  367.920443]  [<c16565bd>] __mutex_lock_slowpath+0x10d/0x171
Aug 25 10:53:28 lubuntu kernel: [  367.920454]  [<c1655aec>] mutex_lock+0x1c/0x28
Aug 25 10:53:28 lubuntu kernel: [  367.920478]  [<f857223a>] acpi_smbus_transaction+0x48/0x210 [sbshc]
Aug 25 10:53:28 lubuntu kernel: [  367.920489]  [<c11858e1>] ? do_last+0x1b1/0xf60
Aug 25 10:53:28 lubuntu kernel: [  367.920504]  [<f857242f>] acpi_smbus_read+0x2d/0x33 [sbshc]
Aug 25 10:53:28 lubuntu kernel: [  367.920520]  [<f881e0f1>] acpi_battery_get_state+0x74/0x8b [sbs]
Aug 25 10:53:28 lubuntu kernel: [  367.920535]  [<f881e8a9>] acpi_sbs_battery_get_property+0x2a/0x233 [sbs]
Aug 25 10:53:28 lubuntu kernel: [  367.920549]  [<c14fa61f>] power_supply_show_property+0x3f/0x240
Aug 25 10:53:28 lubuntu kernel: [  367.920561]  [<c114664f>] ? handle_mm_fault+0x64f/0x8d0
Aug 25 10:53:28 lubuntu kernel: [  367.920573]  [<c14fa5e0>] ? power_supply_store_property+0x60/0x60
Aug 25 10:53:28 lubuntu kernel: [  367.920586]  [<c1407d20>] ? dev_uevent_name+0x30/0x30
Aug 25 10:53:28 lubuntu kernel: [  367.920597]  [<c1407d38>] dev_attr_show+0x18/0x40
Aug 25 10:53:28 lubuntu kernel: [  367.920608]  [<c11dad15>] sysfs_seq_show+0xe5/0x1c0
Aug 25 10:53:28 lubuntu kernel: [  367.920621]  [<c119846e>] seq_read+0xce/0x370
Aug 25 10:53:28 lubuntu kernel: [  367.920633]  [<c11983a0>] ? seq_hlist_next_percpu+0x90/0x90
Aug 25 10:53:28 lubuntu kernel: [  367.920644]  [<c1179238>] vfs_read+0x78/0x140
Aug 25 10:53:28 lubuntu kernel: [  367.920654]  [<c11799a9>] SyS_read+0x49/0x90
Aug 25 10:53:28 lubuntu kernel: [  367.920667]  [<c165efcd>] sysenter_do_call+0x12/0x28
/var/log/installer/debug shows upower related error:
Ubiquity 2.18.8
Gtk-Message: Failed to load module "overlay-scrollbar"
ERROR:dbus.proxies:Introspect error on :1.23:/org/freedesktop/UPower: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Exception in GTK frontend (invoking crash handler):
Traceback (most recent call last):
  File "/usr/lib/ubiquity/bin/ubiquity", line 636, in <module>
    main(oem_config)
  File "/usr/lib/ubiquity/bin/ubiquity", line 622, in main
    install(query=options.query)
  File "/usr/lib/ubiquity/bin/ubiquity", line 260, in install
    wizard = ui.Wizard(distro)
  File "/usr/lib/ubiquity/ubiquity/frontend/gtk_ui.py", line 290, in __init__
    mod.ui = mod.ui_class(mod.controller)
  File "/usr/lib/ubiquity/plugins/ubi-prepare.py", line 93, in __init__
    upower.setup_power_watch(self.prepare_power_source)
  File "/usr/lib/ubiquity/ubiquity/upower.py", line 21, in setup_power_watch
    power_state_changed()
  File "/usr/lib/ubiquity/ubiquity/upower.py", line 18, in power_state_changed
    not misc.get_prop(upower, UPOWER_PATH, 'OnBattery'))
  File "/usr/lib/ubiquity/ubiquity/misc.py", line 809, in get_prop
    return obj.Get(iface, prop, dbus_interface=dbus.PROPERTIES_IFACE)
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 70, in __call__
    return self._proxy_method(*args, **keywords)
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 145, in __call__
    **keywords)
  File "/usr/lib/python3/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
bain
  • 12,200
Rantanplan
  • 315
  • 13
Installation with the alternate installer for Lubuntu 14.04.1 and the forcepae option worked.
First, the problem seemed to have been a badly partitioned hard drive (with an unallocated space between two partitions). In contrast to the normal installer, the alternate installer did not fail at the beginning, so one could manually ask the installer not to mount the existing partitions and to use the whole disk for Lubuntu.
However, now, two other problems came up: the newly installed system cannot be shut-down probably (see Lubuntu: neither shut-down nor restart works) and does not recognise USB sticks (same problem as in USB recognized but not available?). Both problems did not occur using the installation CD as live CD.
Therefore, I wanted to try the "normal" installation CD again, but it fails with the same error message as it did before:
Once being in that desktop session, tail -n 800 -F /var/log/kern.log lists the following (sorry for being long; I do not know what might be important): see https://www.dropbox.com/s/uohd7vmq1ws9oep/Output.txt?dl=0
The content of /var/log/installer from...
  1. ...installation with alternate installer: https://www.dropbox.com/sh/qv7o8w6t5s31xzk/AADmkNP1KP1IaMKOxRfsclRAa?dl=0
  2. ...unsuccessful installation with usual installer: https://www.dropbox.com/sh/dhon6asbz1swms5/AACc3WtvvpIH34_WqA3u3p18a?dl=0
Rantanplan
  • 315
  • 13
This looks like a bug, upowerd is hanging for some reason. There is a similar but unanswered report on the Ubuntu forums here and Mint forums here (the suggested reason there is something to do with reporting the battery status: "at present my system will not show me charge status")
I would suggest reporting the bug on Launchpad and possibly on the upower mailing list. It does seem a rare bug though, so there may be no solution unless you are willing to debug it yourself.
You might be able to workaround the problem by sudo to root and then edit /usr/lib/ubiquity/ubiquity/upower.py and change the has_battery function to:
def has_battery():
    return False
That should force ubiquity to ignore the battery power and carry on with the installation.
bain
  • 12,200
