The package ncview requires X development headers and headers.
On Ubuntu 12.04 I tried the following command sudo apt-get install xorg-dev and I got the below error message.
This looks like a very long list of packages. Is there something I am missing ?
Reading package lists...
Building dependency tree...
Reading state information...
 xorg-dev : Depends: libdmx-dev but it is not going to be installed
            Depends: libfs-dev but it is not going to be installed
            Depends: libx11-dev but it is not going to be installed
            Depends: libxaw7-dev but it is not going to be installed
            Depends: libxcomposite-dev but it is not going to be installed
            Depends: libxcursor-dev but it is not going to be installed
            Depends: libxdamage-dev but it is not going to be installed
            Depends: libxext-dev but it is not going to be installed
            Depends: libxfixes-dev but it is not going to be installed
            Depends: libxfont-dev but it is not going to be installed
            Depends: libxft-dev but it is not going to be installed
            Depends: libxi-dev but it is not going to be installed
            Depends: libxinerama-dev but it is not going to be installed
            Depends: libxkbfile-dev but it is not going to be installed
            Depends: libxmu-dev but it is not going to be installed
            Depends: libxmuu-dev but it is not going to be installed
            Depends: libxpm-dev but it is not going to be installed
            Depends: libxrandr-dev but it is not going to be installed
            Depends: libxrender-dev but it is not going to be installed
            Depends: libxres-dev but it is not going to be installed
            Depends: libxss-dev but it is not going to be installed
            Depends: libxt-dev but it is not going to be installed
            Depends: libxtst-dev but it is not going to be installed
            Depends: libxv-dev but it is not going to be installed
            Depends: libxvmc-dev but it is not going to be installed
            Depends: libxxf86dga-dev but it is not going to be installed
            Depends: libxxf86vm-dev but it is not going to be installed
            Depends: xserver-xorg-dev but it is not going to be installed
Mitch
  • 109,787
gansub
  • 293
Quoted from Ncview on Ubuntu (with a couple formatting and capitalization changes):
Your hint is fine, but you still have to install some packages first:
sudo apt-get install libxt-dev xaw3dg-dev
sudo apt-get install libnetpbm10-dev # ppm support
In addition to this is two links are needed:
cd /usr/include/X11 ; ln -s Xaw3d Xaw
cd /usr/lib/        ; ln -s libXaw.so.7 libXaw.so
You should also install xorg-dev:
Continuing with those instructions:
(This looks inconsistent as we mix Xaw3d header with the Xaw lib, but anyway) after that
./configure --x-libraries=/usr/X11R6/lib
make
make install
does the job!
Eliah Kagan
  • 119,640
