133
I am trying to redirect the output of a bash command into a new file.
If I try the pipe as below :
ls -la | vim
Bash shows me the errors :
Vim: Error reading input, exiting...
Vim: preserving files...
Vim: Finished.
I know that I can open Vim and then use :
:r !ls -la
But is there a way to do this in bash itself, so that Vim is opened and the output is pasted there automatically?
muru
  • 207,228
faizal
  • 3,037
7 Answers7
213
You can use process substitution (this also works with applications that can't read from STDIN):
vim <(ls -la)
Or use vim's function to read from STDIN:
ls -la | vim -
muru
  • 207,228
chaos
  • 28,186
62
You're really close on your own. You were just missing one character.
ls -la | vim -
Cris Holdorph
  • 979
Here's another approach, hopefully to teach someone something new.
If you know that the command :r !ls -la works inside vim, you can do the following to open vim and make it run the command as soon as it opens, straight from bash:
vim -c ':r! ls -la'
This is the equivalent of opening vim then executing the command :r! ls -la. This should work with any vim command, where the command comes after the -c option.
Alaa Ali
  • 32,213
15
You can tell vim to open stdin:
ls -la | vim -
iffy
  • 1,127
I would like to add an option
ls -al | view -
view is a read-only version of vim(equivalent to vim -R)
setlocal buftype=nofile
This is a good option if you are going to create an alias to replace less:
seq 100 | vim +':setlocal buftype=nofile' -
Now you don't need to type the ! to quit.
Another option is:
seq 100 | vim +'nnoremap q :quit!' -
so you can exit with just q<enter>.
If your goal is simply to get the output into a text file then you don't need to invoke vim. Bash can do it alone with
ls -la > outputfile.txt
