173
Can anyone tell me the difference between ctrl+z and ctrl+c?
When I am in the terminal, both the combinations stop the current process, but what exactly is the difference between both?
chaitanya lakkundi
  • 1,891
  • 13
6 Answers6
208
If we leave edge cases to one side, the difference is simple. Control+C aborts the application almost immediately while Control+Z shunts it into the background, suspended.
The shell send different signals to the underlying applications on these combinations:
  • Control+C (control character intr) sends SIGINT which will interrupt the application. Usually causing it to abort, but this is up to the application to decide.
  • Control+Z (control character susp) sends SIGTSTP to a foreground application, effectively putting it in the background, suspended. This is useful if you need to break out of something like an editor to go and grab some data you needed. You can go back into the application by running fg (or %x where x is the job number as shown in jobs).
    We can test this by running nano TEST, then pressing Control+Z and then running ps aux | grep TEST. This will show us the nano process is still running:
    oli     3278  0.0  0.0  14492  3160 pts/4    T    13:59   0:00 nano TEST
    Further, we can see (from that T, which is in the status column) that the process has been stopped. So it's still alive, but it's not running... It can be resumed.
    Some applications will crash if they have ongoing external processes (like a web request) that might timeout while they're asleep.
Oli
  • 299,380
30
Ctrl+C is used to kill a process with signal SIGINT, in other words it is a polite kill .
Ctrl+Z is used to suspend a process by sending it the signal SIGTSTP, which is like a sleep signal, that can be undone and the process can be resumed again.
However when a process is suspended, we can resume it again by fg (resume in foreground) and bg (resume in background) , but I can't resume a killed process, that is a difference between using Ctrl+C & Ctrl+Z.
How can we view suspended processes?
The jobs command gives output like this:
[1]-  Stopped                 cat
[2]+  Stopped                 vi
How to kill a suspended process in background?
By using the kill command:
kill %n where n is the number displayed by the jobs command. So if I want to kill cat: kill %1.
Zanna
  • 72,312
nux
  • 39,152
22
Control+Z suspends a process (SIGTSTP) and Control+C interrupts a process (SIGINT)
http://en.wikipedia.org/wiki/Control-Z
On Unix-like systems, Control+Z is the most common default keyboard mapping for the key sequence that suspends a process
http://en.wikipedia.org/wiki/Control-C
In POSIX systems, the sequence causes the active program to receive a SIGINT signal. If the program does not specify how to handle this condition, it is terminated. Typically a program which does handle a SIGINT will still terminate itself, or at least terminate the task running inside it
Bex
  • 228
12
To put it simply:
  • CTRL-C requests that the program abort.
  • CTRL-Z suspends the program and it remains resident as a background task.
    Suspending a program allows you to resume it later with the command fg. Remaining background tasks are killed when you exit the login shell.
Note that CTRL-C only requests that a program abort, and the program may ignore the request. CTRL-Z will suspend the program unless the program specifically overrides the request.
thomasrutter
  • 37,804
This should help
Ctrl+Z is used for suspending a process by sending it the signal SIGSTOP, which cannot be intercepted by the program. While Ctrl+C is used to kill a process with the signal SIGINT, and can be intercepted by a program so it can clean its self up before exiting, or not exit at all.
graham
  • 13,061
when you press ctrl+c, it means you send SIGINT to your process. like you type this command: kill -SIGINT <your_pid>. It will kill you your process. That why you cannot see it when issue ps command.
When you press ctrl+z, it means you send SIGSTOP to your process. like you type this command: kill -SIGKSTOP <your_pid>. It will stop your process, but the process still alive. So you can re-activate your process by sending SIGCONT to your process.
Benoit
  • 7,637
