How to download a package with all its dependencies So that it can be installed later on another computer without the internet. I tried at Official packages for Ubuntu. But it also needs to be download individually all dependencies.
To see a list of a packages dependencies and to also see if the dependencies are already installed, use the application apt-rdepends
sudo apt-get apt-rdepends
To list dependencies and status of all dependencies as well use 'apt-rdepends -p' like this:
apt-rdepends -p packagename
example:
apt-rdepends -p sl
The output will show the dependencies for the package "sl", the dependencies of the depnedencies, the dependencies of the dependencies dependencies etc.
The output will also show if these are installed or not installed on the computer (status).
Another option, try to get all of the installation packages installed on the box with no internet so that you can just build the packages from source. The source code ususally has the package dependencies that get compiled along with the package. What is not included is the build dependencies you need to compile the code. It's pretty straightforward; most of the time, the build compile and or make installation instructions are described in the "README" , the readme.md (markdown), or the "INSTALL" file. If automake, run ./autogen.sh first, then run ./configure, make, make install.
You can build from source with
sudo apt-get build-dep packagename
sudo apt-get source packagename
Replace "packagename" with the actual package name, of course.
This will first install the build-dependencies needed to compile and install the package (you can take note of what these are) and then, will download the source archives. You must have the "source code" repositories enabled in your /etc/apt/sources.list file (uncomment all "deb-src" entries) or in the ubuntu-software-center to download the source code.
Source code can also be downloaded from the projects website or better yet cloned from "github"
Also, if you have python installed, you can install python packages downloaded from pypi.python.org/
For example, to download and install "youtube-dl" you can download the source code from https://pypi.python.org/packages/source/y/youtube_dl/youtube_dl-2014.08.10.tar.gz#md5=d5d259bf8a2ec1b7bf3b744c173308d9 unzip the package in your home directory ( ~/ ) and to install, you would run these commands:
cd youtube_dl-2014.08.10
python setup.py install
if you get an error you may need to use sudo python setup.py install instead. Although it would be silly to try and download youtube videos with no internet. :)
- 44,904
- 8
- 102
- 162
