A new Ubuntu user here. I just installed Ubuntu 14.04 on my gigabyte U24F laptop. At first the touch-pad (I believe it's elantech) was working fine but one day I turned it off using fn+f10 key from the keyboard. The next day I could no longer turn it back on and it has since been undetected by the system.
xinput returns
Virtual core pointer                        id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ Logitech USB Optical Mouse                id=11   [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Sleep Button                              id=8    [slave  keyboard (3)]
    ↳ Video Bus                                 id=9    [slave  keyboard (3)]
    ↳ Power Button                              id=10   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=12   [slave  keyboard (3)]
so there's no touch-pad detected. I'm using a USB mouse at the moment.
Attempting to run synclient gives
"Couldn't find synaptics properties. No synaptics driver loaded?"
Things I've tried so far to no avail
  • Reinstalling xserver-xorg-input-synaptics.
  • Checking dconf.editor settings, touchpad is enabled.
  • Booting into a live usb session, touchpad no longer even works in this case. (Does this mean a fresh install wouldn't even solve the problem?)
Any help is greatly appreciated!
Mitch
  • 109,787
user314973
Try the following
cat /proc/bus/input/devices | grep Name
Output should include > Elantech Touchpad
If so download the following
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1166442/+attachment/3941591/+files/psmouse-elantech-x551c.tar.gz
Open a terminal, and follow these steps
cd ~/Downloads sudo dkms ldtarball psmouse-elantech-x551c.tar.gz sudo dkms install -m psmouse -v elantech-x551c
sudo rmmod psmouse sudo modprobe psmouse
HTH
Reference
