I am trying to write a C program to add a new user to my Ubuntu 14.04.
I edited
1) /etc/passwd
sachin:x:65535:1:sachin:/home/sachin:/bin/bash
2) /etc/shadow
sachin:$6$VwBWgroA$t4KXLWIf81sWtiA1/a.fRLrXaOAflGtMo73hGvCzp/M6S8oizZ4iqk.vYbkblXZj2hgGXJxlJ.M2hghGO.a650:16294::::::
3) .profile
stty istrip
PATH=/bin:/usr/bin:/usr/local/bin:/usr/share/bin:.
export PATH
After this when I run - ls -l /home/
drwxr-xr-x 43 mrcr mrcr 4096 Aug 12 10:27 mrcr
d-w------t  2 sachin    daemon    4096 Aug 12 11:11 sachin
Where "sachin" is created by my rpogram, "mrcr" is created normally. I changed the permissions like a normal user home
drwxr-xr-x 2 sachin    daemon    4096 Aug 12 11:11 sachin
I copied all files from "mrcr" home directory to "sachin" home directory(.bashrc, Desktop ..etc)
Now in login screen "sachin" is there to login. but even if I enter correct password I can't login into it. It will load again the same login screen. given below is my entire code,
#include<stdio.h>
#include<string.h>
#include<stdlib.h>
#include <sys/types.h>
#include <pwd.h>
#include<signal.h>
#include<unistd.h>
main(int argc, char **argv)
    struct passwd *userlist;
    int count, usernumber, len1;
    FILE *tmp, *stmp, *mailer, *profile;
    char *commentfield, *username, *userdir, *home;
    char *mailcomment, *mailmail, reply;
    commentfield = (char *)malloc(1024*sizeof(char));
    username = (char *)malloc(8*sizeof(char));
    userdir = (char *)malloc(256*sizeof(char));
    home = (char *)malloc(256*sizeof(char));
    mailcomment = (char *)malloc(1024*sizeof(char));
    mailmail = (char *)malloc(512*sizeof(char));
    if (argc!=4)
        printf("usage : %s [dirname- no slashes] [logname] [comment - in quotes]\n", argv[0]);
        exit(1);
    if( (strlen(argv[2]) < 5) || (strlen(argv[2]) > 8) )
        printf("pls enter logname between 5-8 \n");
        exit(1);
    signal(SIGHUP, SIG_IGN);
    signal(SIGINT, SIG_IGN);
    setpwent();
    count = 0;
    while((userlist = getpwent()) != NULL)
        if(count < userlist->pw_uid)
            count = userlist->pw_uid ;
            usernumber = count + 1;
    printf("usernumber : %d\n", usernumber);
    endpwent();
    sprintf(commentfield,"%s", argv[3]);
    sprintf(username, "%s", argv[2]);
    sprintf(userdir, "%s", argv[1]);
    sprintf(home, "/%s/%s", argv[1], argv[2]);
    printf("\n Check this out here: \n");
    printf("-----------------------------------------------");
    printf("\n username      :\t %s", username);
    printf("\n Home Directory:\t %s", home);
    printf("\n comment       :\t %s", commentfield);
    printf("\n______________________________________________\n\n");
    printf("all of this ok? n/y: ");
    scanf("%c", &reply);
    if(reply != 'y')
        printf("\n exiting....u entered not y");
        exit(1);
    tmp = fopen("/etc/passwd", "a");
    if (tmp == NULL)
        printf("\npermission denied\n");
        exit(1);
    fprintf(tmp, "%s:x:%d:1:%s:%s:/bin/bash\n", username, usernumber, commentfield, home);
    fclose(tmp);
    stmp = fopen("/etc/shadow", "a");
    if (stmp == NULL)
        exit(1);
    fprintf(stmp, "%s:*LK*:::::::\n", username);
    fclose(stmp);
    mkdir(home, 0755);
    chdir(home);
    profile = fopen(".profile", "a");
    fprintf(profile, "stty istrip\n");
    fprintf(profile, "PATH=/bin:/usr/bin:/usr/local/bin:/usr/share/bin:.\n");
    fprintf(profile, "export PATH\n");
    fprintf(profile, "\n\n");
    fclose(profile);
    chown(home, usernumber, 1);
    chown(".profile", usernumber, 1);
    chmod(".profile", 0644);
    printf("\n\nALL done!!!!!!!\n Now set the password: ");
    execl("/usr/bin/passwd", "passwd", username, NULL);
    printf("\n\n SUCCESS PASSWORD IS SET.....BYE!!!\n\n");
QUESTIONS:
  1. what are the files needs to be edit?
  2. How can i run the program without to be a root?
  3. what changes i needs to put in my code?
Mateo
  • 8,152
I'll post answer but note that there is tool adduser which is less error-prone and more complex.
  1. Source - http://www.tldp.org/LDP/sag/html/adduser.html
11.2.4. Creating a user by hand
To create a new account manually, follow these steps:
Edit /etc/passwd with vipw and add a new line for the new account. Be careful with > the syntax. Do not edit directly with an editor! vipw locks the file, so that other commands won't try to update it at the same time. You should make the password field be `*', so that it is impossible to log in.
Similarly, edit /etc/group with vigr, if you need to create a new group as well.
Create the home directory of the user with mkdir.
Copy the files from /etc/skel to the new home directory.
Fix ownerships and permissions with chown and chmod. The -R option is most useful. > The correct permissions vary a little from one site to another, but usually the following commands do the right thing:
cd /home/newusername
chown -R username.group .
chmod -R go=u,go-w .
chmod go= .
Set the password with passwd.
After you set the password in the last step, the account will work. You shouldn't set it until everything else has been done, otherwise the user may inadvertently log in while you're still copying the files.
  1. You can use polkit (formerly known as Policy Kit).
3.:
  • main function should be returning integer (int).
  • don't copy .profile, copy whole /etc/skel directory
enedil
  • 1,002
