Having some problems! Every time I try perform the update from 12.04 to 14.04 I am met with the following error:
kev@masterpc:~$ sudo do-release-upgrade
Checking for a new Ubuntu release
Err Upgrade tool signature
  404  Not Found [IP: 91.189.91.15 80]
Err Upgrade tool
Fetched 0 B in 0s (0 B/s)
WARNING:root:file 'quantal.tar.gz.gpg' missing
Failed to fetch
Fetching the upgrade failed. There may be a network problem.
In the software centre under software sources I have used both servers (Australian & Main server) but to no avail. My network also appears to be fine!
Bubba
Figured it out!
In the software centre -> Software sources under the updates tab you must change "Notify me of a new Ubuntu version:" set to "For long term support versions" then in a terminal run
sudo apt-get update
sudo do-release-upgrade -d
Running the update command seems to be critical, so don't forget it!
Bubba
