14
I have a problem with Ubuntu 14.04 and playing DVD's.
After installing 14.04 I came to the conclusion that I can not play any DVD's. DVD's cannot even be opened as they are not seen by Ubuntu.
The data I have until now:
  • In the install of 13.10 this was no problem, so this excludes a hardware problem
  • It's on 2 installs on 2 different computers.
  • It concerns a Ubuntu and Lubuntu install
  • The different libdvd libraries are installed:
    • libdvdread4 : version 4.2.1-2ubuntu1
    • libdvdnav4 : version 4.2.1-3
    • libdvdcss2 : version 1.2.13-0
    • ubuntu-restricted-extras : version 60
    • acidrip : version 0.14-0.2ubuntu7
  • The dvd is found on /dev/sr0
  • eject /dev/sr0 does work like a charm
  • sudo mount /dev/sr0 /tmp/dvd makes DVD to in but doesn't mount
  • lshw on cdrom gives the DVD player with the <status=nodisc> when there is a dvd in it!
  • playing a CD is no problem
  • ls -l /dev/sr0 gives :
    brw-rw----+ 1 root cdrom 11, 0 aug 9 20:20 /dev/sr0
    • I am in group cdrom
  • vlc doesn't work as doesn't acidrip for that matter or mplayer
  • changing regions doesn't work as the computer thinks there's no disc.
  • vlc doesn't have problems with encyption (region) but just can't open /dev/sr0
  • when using vlc as root it gives the same error, so it won't be a rights problem
vlc -vvv /dev/sr0 gives a lot and this:
libdvdnav: Using dvdnav version 4.2.1
libdvdread: Could not open /dev/sr0 with libdvdcss.
libdvdread: Can't open /dev/sr0 for reading
libdvdnav: vm: failed to open/read the DVD
[0x7f1d18000e78] dvdnav demux warning: cannot open DVD (/dev/sr0)
So now I am stuck with two installs of Ubuntu 14.04 which don't play any DVD's. Can somebody help and/or ask some questions which lead me to an answer?
Pabi
  • 7,429
linuxpete
  • 159
5 Answers5
Try cleaning your DVD drive optical head. I had some flaky DVD recognition, similar symptoms, which got much better after cleaning the laser lens.
Mau
  • 41
Also, be sure that your user is in the cdrom group.
This right is gained by adding the user to the "cdrom" group.
The "cdrom" group owns the CD-ROM devices in /dev.
Source: https://wiki.ubuntu.com/Security/Privileges#Use_CD-ROM_drives
oxr463
  • 275
  • 16
Did you try running sudo /usr/share/doc/libdvdread4/install-css.sh ?
It is a " shell script to install libdvdcss under Debian GNU Linux, many DVDs use css for encryption. To play these discs, a special library is needed to decode them, libdvdcss. Due to legal problems, Debian and most Linux distibutions cannot distribute libdvdcss "
This script will also install VLC if necessary
I do read that you have libdvdcss2 installed already, but in my experience I had to run this script before I could play DVD's.
Jacob
  • 29
For 18.04:
sudo apt-get purge libdvd-pkg
sudo apt-get install libdvd-pkg
sudo dpkg-reconfigure libdvd-pkg
If you still can't get it to play, try borrowing a USB DVD player from somewhere. My new PC came with such a lame no-name DVD drive, it wouldn't play anything.
Adam
  • 1,149
I cleaned the optical heads on the drives and ... voila!!! I can now mount the drives.
David DE
  • 2,316
