Yoga 11s wifi card drivers are not pre-installed. I have followed numerous instructions online all of which include downloading the same package, unzipping it, making it, sudo make install. A summary is here. Every variation of this method I have used fails with the same two errors. Two "No such file or directory" errors when I try to "make" the code. I have checked to make sure my kernels headers are installed, because someone said they aren't by default. I believe that person is wrong. @chili555 requested lspci -nn, grep 0280, lsb_release -d. They are in that order.
lspci -nn:
00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09)
00:04.0 Signal processing controller [1180]: Intel Corporation 3rd Gen Core Processor Thermal Subsystem [8086:0153] (rev 09)
00:14.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller [8086:1e31] (rev 04)
00:16.0 Communication controller [0780]: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 [8086:1e3a] (rev 04)
00:1a.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 [8086:1e2d] (rev 04)
00:1b.0 Audio device [0403]: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller [8086:1e20] (rev 04)
00:1d.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 [8086:1e26] (rev 04)
00:1f.0 ISA bridge [0601]: Intel Corporation QS77 Express Chipset LPC Controller [8086:1e56] (rev 04)
00:1f.2 SATA controller [0106]: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] [8086:1e03] (rev 04)
00:1f.3 SMBus [0c05]: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller [8086:1e22] (rev 04)
00:1f.6 Signal processing controller [1180]: Intel Corporation 7 Series/C210 Series Chipset Family Thermal Management Controller [8086:1e24] (rev 04)
grep 0280 removes the directory and my user name, but nothing else. I can type and hit enter but as far as I can tell it does nothing.
lsb_release -d gives the output:
Description: Ubuntu 14.04.01 LTS
lsusb gives the output:
Bus 002 Device 005: ID 5986:053d Acer, Inc
Bus 002 Device 004: ID 0bda:1724 Realtek Semiconductor Corp.
Bus 002 Device 003: ID 2047:0855 Texas Instruments
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 03eb:8814 Atmel Corp.
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 058f:6387 Alcor Micro Corp. Flash Drive
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Wireless is enabled in the BIOS, and it works in the Windows 8 partition.
Denthil
  • 33
Here is your device:
It is covered by the driver 8723au which must be compiled from source. First, verify that you have the prerequisites installed:
sudo apt-get install build-essential linux-headers-generic
You need to verify that both are installed before we proceed. If so, download this file and move it to your desktop: https://github.com/lwfinger/rtl8723au/archive/kernel_version.zip Right-click it and select 'Extract Here.' Now, in the terminal:
cd ~/Desktop/rtl8723au-kernel-version
make
sudo make install
sudo modprobe 8723au
Please post any errors or other snags. I will have another edit.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
chili555
  • 61,330
