Let me start off by saying I'm dual booting 11.04 and Windows 7 on a Thinkpad T61p.
The problem may have arisen when I hit the power button during normal startup. I'm fully aware how stupid this is. I don't know why I did it. I did it.
Now, I can't get in to Ubuntu. Windows works fine. But when I try to start Ubuntu normally, it seems to run some checks, and does not start up. Sometimes, I see a black screen, and it tells me that it's running certain checks, and then, [ok]. Like... Battery Check Somethingorother [ok]
It'll give me 1-5 of these. And then it just does nothing, and I have to turn it off.
When I try to start in safe mode... I tried low graphics mode, and after going through a couple of dialogue boxes, I'm brought right back to the safe mode dialogue box. And if I hit 'resume,' a shell pushes up (still that grey on black "your computer is broken" type shell) and asks me to log in. I do, and try to run unity. It tells me something along the lines of: WARNING no DISPLAY variable set and then sets it to " :0" , which doesn't work.
And then I can't do anything, really, and I have to restart. (I don't know how to do this from the command line, so I just hard reset. That command would be helpful).
Does anybody have any idea how I can get Ubuntu working right again? FTP is less pleasant in Explorer than it is in Nautilus or w/e it is now.
Isaiah
  • 60,750
Daniel
  • 1,939
First instead of pushing the Power Button try this command sudo reboot . As for the issues your having with unity not loading in safe mode or normal try to boot . Type sudo apt-get remove unity which should remove unity . Then type sudo apt-get install unity to reinstall you may get lucky . Chances are your going need to reformat ubuntu with your cd.
freebird
  • 386
before formatting your HD or performing irreversible actions, consider using a livecd. your computer isn't 'broken'. you may want to check if your partition table is ok and your data is still there. if so, you may simply have to check your fs, which could be damaged. a file system check may be able to correct the errors. still, i can't understand why you managed to break your system. in order to check the status of your HD (it may be physically damaged) you may want to have a look at the smartmontools package which contains a tool to examine the conditions of your HD. I don't think re-installing any package will solve your problem but the configuration files of some packeges may be corrupted. then, remember that a re-installation (with --purge, maybe, but use it at your own risk) will overwrite the old conf files and create new ones. and remember that if acpid is installed and properly configured, a single, little push on the power button will cause your computer to shut down genlty, with no consequences.
and, this is a good chance to learn some odd command line stuff! :)
