I just performed a suggested update by the Update Manager on Ubuntu 14.04, and now I get no video when I reboot.
I get the splash screen, then it goes black.
Can I somehow switch back to default X drivers from terminal?
bmcgonag
  • 171
Had the same problem today, here's what helped me:
  1. Boot into recovery mode and get into root shell (screenshots).
  2. Make root partition writable: mount -o remount rw /
  3. Remove all nvidia packages: apt-get remove --purge nvidia*
  4. Reboot into normal mode: reboot
Now you are using open source Nouveau driver. If you wish, you can reenable Nvidia binary driver.
Shevchuk
  • 373
Reboot and enter into recovery mode By Pressing SHIFT Key
After reaching the menu choose drop to shell
Then execute the command
sudo mount -o remount rw /
Edit the file
# sudo gedit /etc/default/grub
And modify the line :
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
It to obtain this line :
GRUB_CMDLINE_LINUX_DEFAULT="acpi=noirq acpi=force apm=power_off quiet splash"
Then, save, close, and back in the terminal, execute :
# sudo update-grub
Now, when you will Shutdown, it should Work great.
