How can I set my mouse cursor to be black on Ubuntu 14.04?
            Asked
            Active
            Viewed 1.9k times
            - Open terminal and type: - cp -r /usr/share/icons/DMZ-White ~/Documents/- This is to make a backup of the current theme. (just in case you want to reverse the changes)
- Next copy the icon folder to replace the icons with this command: - sudo cp -r /usr/share/icons/DMZ-Black/* /usr/share/icons/DMZ-White/
- Logout and login, there you have it, a nice black mouse cursor.
To recover the white mouse cursor, from your backup, do the following command then logout and in again:
sudo cp -r ~/Documents/DMZ-White/* /usr/share/icons/DMZ-White/
