I have built an unattended setup ISO for Ubuntu 12.04.4 using instructions provided on the community wiki, however, I'm having a hard time with two specific pieces of the install:
- The installer hangs for a couple of minutes about three minutes into the installation process, with a "Retrieving file 1 of 1" message. The kickstart configuration has it pointed at a local update mirror, so there's no reason the installer should be trying to call out to the internet (indeed, the network is set up so that it has no route to do so).
Looking at the created sources.list file after install, I see that the internet-facing Security repos have been enabled (http://security.ubuntu.com stuff). This is the only thing I can see which should lead to this timeout during the install.
Question the first: What do I need to drop into the Kickstart file to ensure this is either disabled outright, or redirected internally?
- Secondly, despite adopting the preseed settings from the "Minimal virtual machine" install reached by hitting F4 on the boot screen, my resulting install is hardly minimal. A dead giveaway is that the Landscape advertising blurb appears on the MOTD during my automated install, but not if I select "minimal virtual machine" and do the install by hand.
Question the second: How do I ensure that I get a "minimal virtual machine" installation when using Kickstart?
Below is a version of my kickstart file. This is loaded into the standard 12.04.4 server ISO.
Thanks in advance!
#System language
lang en_US
#langsupport en_US
keyboard us
timezone --utc America/Denver
#Root password (standard)
rootpw --iscrypted password-goes-here
#Skip initial user, root only.
user --disabled
#Reboot after installation
reboot
#Use text mode install
text
#Install OS instead of upgrade
install
#Install from update server (replace with 'cdrom' to use local)
url --url http://internal-server/archive-ubuntu/ubuntu/
#Setup NTP
preseed clock-setup/ntp boolean true
preseed clock-setup/ntp-server string internal-ntp-server
#Use our local repo instead of going out to the internet
preseed mirror/country string manual
preseed mirror/http/hostname string internal-server
preseed mirror/http/directory string /archive-ubuntu
preseed mirror/http/proxy string
preseed mirror/http/mirror internal-server
#Ensure a minimal install
#Options taken from ISO/preseed/ubuntu-server-minimalvm.seed
preseed base-installer/kernel/headers boolean false
preseed tasksel/skip-tasks string standard
preseed pkgsel/language-pack-patterns string
preseed pkgsel/install-language-support boolean false
preseed base-installer/kernel/altmeta string lts-saucy
#System bootloader configuration
bootloader --location=mbr
#For safety, initialize everything
#Clear the Master Boot Record
zerombr yes
#Partition clearing information
clearpart --all --initlabel
#Partition Setup
#Redacted
#System authorization information
auth --useshadow --enablemd5
#Network information
#Redacted
#Firewall configuration
firewall --disabled
#Do not configure the X Window System
skipx
