I have an ISO image with a UDF filesystem and a boot sector and I need to add a file to it. When I do
sudo mount -o loop,rw /tmp/file.iso /tmp/dir
I get
mount: block device /tmp/file.iso is write-protected, mounting read-only
This happens even if I remove loop or add unhide. The file has permissions rw-rw-rw-. I have tried various UDF command-line tools, but they all demand an actual CD drive, and won't even work with the loopback device. So is there anything I can do?
Because this has a boot sector, I'd rather edit the ISO file directly than unpack/repack.
Using Kubuntu 14.04 here. Thanks.
andlabs
  • 503
I'm able to browse, add and delete files in an ISO file without unpacking/repacking it by simply opening it with the Archive Manager (Ubuntu 14.04).
Hopefully you can do the same using Kubuntu.
SNugues
  • 89
What you've done is somewhat correct, but you must login as a root user.
sudo su -
Create a mount point:
mkdir -p /mnt/<mount_name>
The use mount command as follows to mount ISO file .iso:
mount -o loop disk1.iso /mnt/<mount_name>
Change directory to list files stored inside an ISO image:
cd /mnt/<mount_name>
ls -l
Mitch
  • 109,787
