Apparently one of your modifications to .bashrc introduced an error that treats /bin like something other than a directory (for example, by trying to run it as an executable file, read data from or write data to it as a file, etc.). Because .bashrc runs when your interactive shell starts, the error message always appears.
You may be able to identify the error yourself by looking through your modifications to .bashrc.
(Otherwise, to identify the specific problem it will be necessary to see the contents of your .bashrc file. You can copy its entire contents to the clipboard and paste it into your question, select it in your question, and format it as code with Ctrl+K. If you've made this file, much, much longer than it usually is, it might be too long to put into your question in its entirety. In that case, you can post it at http://paste.ubuntu.com and edit your question to include a link to the posting.)
One possibility is that you may have introduced a space in a path starting with /bin. For example, near the beginning of the default .bashrc file is the code:
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
If you accidentally put a space after /bin (in SHELL=/bin/sh), this might produce such an error.
That is just one example, and not necessarily the most likely one.
