As stated in the title, I can't play any commercial DVD on my internal DVD-drive on my laptop, but everything works just fine for the same DVD played on an external (USB) DVD-drive. I've installed ubuntu-restricted-extras and used the usual script: sudo /usr/share/doc/libdvdread4/install-css.sh
I might add that this problem is encountered on 3 different laptops, so it's not a physical problems on my machines (hopefully ;)).
Thanks to anyone who would have a solution... :)
SNugues
  • 89
Well I found myself the answer by launching VLC from the terminal, that gave me:
main input error: ES_OUT_RESET_PCR called
Googling it, I found this: How to play DVDs after installing the recommended libraries?
I had to change the region code (though I never actually changed it...) to "2" (Europe) by installing regionset:
sudo apt-get install regionset
then
regionset /dev/sr0
Confirming I want to change the region code for this DVD-drive, and setting it to "2".
I guess that doesn't explain what the problem was due to, but anyway, it's working now :)
SNugues
  • 89
