Is it possible to install a package for just the current user (placing files in locations that the user can write to, such as their home directory)?
Asked
Active
Viewed 1.5k times
It is not possible to install a package in a way that it would run correctly. The closest thing you could get to this is running apt-get inside a virtual machine or LXC container run by a normal unprivileged user. If you want to just unpack the .deb package, you can use dpkg -x archive.deb target_directory, but the installation scripts will not be run, and it will not be installed to the filesystem root.
bain
- 12,200
