I'm trying to execute a sed command with "-n" option.
for i in 1 2 3 4 5 ; do maas maas nodes list | grep hostname | cut -d\" -f4 | sed -n '$ip'; done
I want it to run sed -n '1p' then sed -n '2p' and so on.
Any idea?
Oli
  • 299,380
You want to replace $i in $ip with your shell variable? Use double-quotes
... | sed "$ip" ...
This has certain implications. It doesn't apply here but you might have to escape things you wouldn't need to in single-quote-marks.
But I'd also consider rewriting that so you're not running the same commands n times to print the first n lines (which is what this does). Here are some alternatives...
Using head:
maas maas nodes list | grep hostname | cut -d\" -f4 | head -5
Storing the command output:
output=$(maas maas nodes list | grep hostname | cut -d\" -f4)
for i in 1 2 3 4 5; do
    sed -n "$ip"
done
Creating a better sed string:
maas maas nodes list | grep hostname | cut -d\" -f4 | sed -n $(printf "%dp;" {1..5})
Roll all your search/trim code into one awk:
maas maas nodes list | awk -F'"' '/hostname/ && i<5 {i++; print $4}'
I'm an awk fetishist so I'd probably go for the last.
Oli
  • 299,380
