I desperately need to install Gimp on my computer. When I enter the Ubuntu Software Center Gimp is easily searchable, but when I click on it to download it says: "Not Found: there isn't a software package called 'gimp' in your current software sources". I've tried to add the program through the terminal using
sudo apt- get install gimp
to which I get the response
E: unable to locate package gimp
I've tried updates and changing my software settings, but nothing has helped and I can't find a clear fix here.
If you have some advice, please share.
Thanks!
Asked
Active
Viewed 1,334 times
Pandya
- 37,289
Can you install other packages? What country are you residing (I mean, set during installation?) May be you have broken regional mirror? open your /etc/apt/sources.list file. It will be full of lines like
deb http://ru.archive.ubuntu.com/ubuntu/ trusty main restricted
Change the regional code to some nearby country and run sudo apt-get update
Barafu Albino
- 6,629
