I`ve been using Linux for four month.
Mint Qiana,Peppermint 3, Lubuntu14.04.1.
When I set up my printer, I downloaded the following:
- cupswrapperHL2270DW-2.0.4-2.i386.deb --Archive
- Brother-HL-2170W-hpijs-pcl5e.ppd --Text
- hl2270dwlpr-2.1.0-1.i386.deb --Archive
My printer may be using these files when printing or have already use them in some manner. These files are designated Type: Archive.
Do these files have to be permanently in the Downloads folder?
Are they being used by the OS where they currently reside or are they remnants from the installation and can be removed/deleted because they have already been incorporated within my printer setup?
If these .deb files are being used, where should they normally be placed other than the Downloads folder or is the Downloads folder the only place to keep these files so they can be used to print?
If these files must be kept, how would I safely relocated them from the Downloads folder and place them in the normal file system so that they remain functional for printing?
Regarding the Brother ppd.Text file :
This file was also sent to the Printer software interface and is being used.
Can this file be safety removed?
I'm not 100% sure I can remove it without rendering my printer setup relegated to become useless?
Here again, the same above questions apply, only in this case regarding this particular Text file.
To answer my own questions, I'm guessing the answer to be:
The ppdText/.deb files: OK to delete them, OS software has stored-saved them in some form and has completed using them. These are remnants and will not effect your printer/other interface/operation if you delete/permanently remove them.
