I have an EC2 instance running Red5 and I added the following script to the scripts that run on startup and shutdown of the server:
################# NOTE FROM DOMINICK
# First Follow these directions
#http://embraceubuntu.com/2005/09/07/adding-a-startup-script-to-be-run-at-bootup/
# Author: Jake Hilton <red5@jakehilton.com>
# /etc/init.d/red5
# Check for missing file
RED5_DIR=/opt/red5
test -x $RED5_DIR/red5.sh || exit 5
case "$1" in
start)
echo -n "Starting Red5 Service"
echo -n " "
cd $RED5_DIR
su -s /bin/bash -c "$RED5_DIR/red5.sh &" infrared5
sleep 2
stop)
echo -n "Shutting down red5"
echo -n " "
##su -s /bin/bash -c "killall -q -u infrared5 java" infrared5
su -s /bin/bash -c "$RED5_DIR/red5-shutdown.sh &" infrared5
sleep 2
restart)
## Stop the service and regardless of whether it was
## running or not, start it again.
$0 stop
$0 start
esac
The only change I made was the location of red5 which is in /usr/share/red5 on my instance.
After Following the instructions on the following site: Adding a startup script to be run at bootup on how to install the script I ran the following command from the terminal /etc/init.d/red5 start and got the following:
I navigate to http://somedomain.com:5080/ which is the red5 start page and I get a 404.
Rebooting the server also seems to have the same effect. Not sure how to touble shoot this one and could use some help figuring out what I may be doing wrong.
