-1
When I'm doing something on the desktop like using firefox and i want to minimize it and also using terminal and i want to minimize it, Ubuntu 14.04 LTS will just randomly freeze. The screen just stops, I can't see my mouse move, etc. However, I can Alt+Ctrl+F2 into a tty terminal (though it's not much use).
However, Sometimes through tty terminal i was able to restart but most times it was not possible. Most times i needed to force shutdown through power button.
What is going on here? How can I fix / stop / prevent this?
Note: My laptop has an nvidia-Geforce setup.
I searched similar problems in the forum and i tried so many solutions but not one solved the problem. From the forum it seems the nvidia driver is the issue but in my case it is not getting solved.
Note : I am using Gnome desktop environment.
Also when i do not do anything long time and Ubuntu lock automatically . after that if i give pass and want to log in it also gets hang.
I recomend you to check another driver for nvidia. Open the Additional Drivers utility (Dash -> Additional Drivers) and try a different version. I have had to change it to nvidia 304 driver since Ubuntu 13.10 for a nvidia GT9800 because the same problem. If you can try this version but it is unavailable, you can install it by using this command: sudo apt-get install nvidia-304
Oskar
