I have not been able to update my redmine. Everytime I ran apt-get upgrade, I'm getting a ruby not found error:
Setting up redmine (2.4.2-1) ...
dbconfig-common: writing config to /etc/dbconfig-common/redmine/instances/default.conf
Creating config file /etc/redmine/default/database.yml.new with new version
dbconfig-common: flushing administrative password
Populating database for redmine instance "default".
This may take a while.
/usr/bin/env: ruby1.8: No such file or directory
Error when running rake db:migrate, check database configuration.
dpkg: error processing package redmine (--configure):
subprocess installed post-installation script returned error exit status 1
redmine
I am stuck now. My redmine has stopped working.
I have tried to "redmine" by linking /usr/bin/ruby1.8 to /usr/bin/ruby, but got stuck with different error.
Setting up redmine (2.4.2-1) ... dbconfig-common: writing config to /etc/dbconfig-common/redmine/instances/default.conf
/usr/lib/ruby/1.9.1/rubygems/dependency.rb:247:in `to_specs': Could not find rake (>= 0) amongst [] (Gem::LoadError)
from /usr/lib/ruby/1.9.1/rubygems/dependency.rb:256:in `to_spec'
from /usr/lib/ruby/1.9.1/rubygems.rb:1231:in `gem'
from /usr/local/bin/rake:18:in `<main>'
redmine
And then I tried with re-installing ruby1.8 by as suggested in this issue. But I got a different error while installing ruby1.8.
apt-get install ruby1.8
Reading package lists... Done
Building dependency tree
redmine-sqlite : Depends: ruby-sqlite3 but it is not going to be installed
ruby-fcgi : Depends: libruby1.9.1 (>= 1.9.2.0) but it is not going to be installed or
libruby2.0 (>= 2.0.0) but it is not going to be installed
ruby-railties-3.2 : Depends: ruby-actionpack-3.2 (>= 3.2.16) but it is not going to be installed
Depends: ruby-actionmailer-3.2 (>= 3.2.16) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
