I am using Dell Inspiron 15R 5521 laptop. It had Ubuntu 12.04 installed at time of purchase. Everything was working fine.Then i installed windows in it and now i have removed windows and installed Ubuntu 14.04 . The problem i am facing is that my touchpad is not detected in it. I searched on google , askUbuntu but could not get solution to my problem. Also i went through this link (https://help.ubuntu.com/community/SynapticsTouchpad) but it did not help. Can you please help me here. Let me know what other information is required here.
Thanks.
Reference: Touchpad under 16.04 not working
Solution #1
  1. Modify the GRUB file with a text editor (nano works too)
    sudo -H gedit /etc/default/grub
  2. Locate this line in the grub file
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
  3. Replace it with the following:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i8042.nopnp"
  4. Save the GRUB file and run the update
    sudo update-grub
  5. Shutdown / reboot for the changes to take effect.
    sudo shutdown -r now
Solution #2
  3. Replace it with the following: (ONLY DIFFERENCE FROM SOLUTION 1)
    GRUB_CMDLINE_LINUX_DEFAULT="i8042.reset quiet splash"
    sudo update-grub
Eliah Kagan
  • 119,640
My research indicate that your laptop has a SynPS/2 Synaptics TouchPad
Execute the following command
xinput list
You should see a output like the following
⎡ Virtual core pointer                      id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer            id=4    [slave  pointer  (2)]
⎜   ↳ Logitech Unifying Device. Wireless PID:1025   id=11   [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard           id=5    [slave  keyboard (3)]
    ↳ Power Button                          id=6    [slave  keyboard (3)]
    ↳ Video Bus                             id=7    [slave  keyboard (3)]
    ↳ Power Button                          id=8    [slave  keyboard (3)]
    ↳ USB Camera                            id=9    [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard          id=10   [slave  keyboard (3)]
    ↳ Toshiba input device                  id=12   [slave  keyboard (3)]
    ↳ Logitech Logitech Wireless Headset    id=14   [slave  keyboard (3)]
To enable the touch pad
xinput set-prop [device id] "Device Enabled" 1
You can do a following to check the properties
xinput --watch-props [device number]
You also can try
lsmod
lsmod | grep mouse (Check the if the touchpad is loaded)
sudo modprobe -r psmouse
sudo modprobe psmouse proto=imps
Also you can take look at following post too.
Touchpad not working on MSi U130 after login in
