I'm in a bit of a pickle. I have just done an upgrade from 13.10 to 14.04, then I rebooted the machine and now the drive/partition is gone, so it boots into memtest.
The drive was encrypted during installation (13.04) using full disk encryption. The update to 13.10 went without issues.
If I use a LiveUSB I can mount the drive just fine, so I assume it's a GRUB problem, but I can't really figure out what's wrong. Does anyone know a way to make the disk visible again from a LiveUSB?
The computer is a Lenovo X1 Carbon, so the SSD is non-removable (The SSD is visible in the BIOS).
Tim
  • 33,500
If you can mount the drive from the live CD, I would set up a chroot environment, and then chroot into the partition. Then, you can use update-grub or similar to fix grub. I assume you mount your cryptfs into /mnt/ and you use grub.
Setting up chroot
Taken from here, run as root:
for f in proc sys dev ; do mount --bind /$f /mnt/$f ; done
To set up the /dev/proc etc.
Starting the chroot
sudo chroot /mnt
Repair Grub
update-grub
That should update your grub setup. After that you are all done, reboot.
If that does not work, we need more detail on your grub configuration and partitions.
noleti
  • 4,103
  • 28
  • 27
