I am running Ubuntu 13.10 32bit. Since a couple of days Skype doesn't work anymore: "Skype can't connect". It is Skype version 4.2. I know there have been other posts regarding this problem. Here it is suggested to update to Skype 4.3 using the software center. I tried this but as far as I can see it the Skype version on the software center is still 4.2. I tried ot anyway, that is, I first uninstalled then reinstalled Skype via the siftware center. But as expected it is still version 4.2. And there it still does not work. Also I checked this site ... but they do not have a version for Ubuntu 13.10. For some reasons I would not like to update Ubuntu to V 14.04 at this point so I would be happy if someone came up with a solution how to fix this problem on Ubuntu 13.10.
lpdbw
  • 273
As explained here, skype will no longer support old versions of skype(including 4.2), so you will have to upgrade to version 4.3. Version 4.3 IS AVAILABLE from the software center. Make sure you checked "Canonical partners" in sources list.
I upgraded to version 4.3.0.37 because version 4.2.0.13 was not allowing me to login anymore with the error “Can’t connect”.
Unfortunately for me after hours of trying I could not get pulseaudio to work on my system, only ALSA is working so I downgraded back to 4.2.0.13
To solve the login error I spoofed the version number 4.2.0.13 to the latest 4.3.0.37 version and login was working again, problem solved.
So to solve your problem simply downgrade back to 4.2.0.13 and spoof to 4.3.0.37 version, exit Skype and run this command:
sudo sed -i "s/\x34\x2E\x32\x2E\x30\x2E\x31\x33/\x34\x2E\x33\x2E\x30\x2E\x33\x37/g" /usr/bin/skype
mikelinux
  • 13
