Wifi will repeatedly cut out after an undetermined amount of time.
I've read the Unstable wireless connection in Ubuntu 14.04 but I don't want to disable N mode b/c I want the faster speed.
I have this card: http://www.intel.com/p/en_US/support/highlights/wireless/cwn-1030
I also tried turning off power management but that doesn't work either
sudo iwconfig wlan0 power off
I ran the wifi script
wget -N -t 5 -T 10 http://dl.dropbox.com/u/57264241/wireless_script && chmod +x wireless_script && ./wireless_script
Here are the results: http://pastebin.com/1AdPQy7D
ahtmatrix
  • 101
There may be some code missing in the kernel. See the following "LTR patch". Updating to the patched kernel may be the solution. (See here for an example how to do this.)
kV.
See: LTR Patch
[PATCH] iwlwifi: configure the LTR
"From eaf90486817fd0c3de2c65d51e9f2841ec352624 Mon Sep 17 00:00:00 2001
From: Emmanuel Grumbach Date: Tue, 23 Sep 2014 23:02:41 +0300
Subject: [PATCH] iwlwifi: configure the LTR
The LTR is the handshake between the device and the root complex about the latency allowed when the bus exits power save. This configuration was missing and this led to high latency in the link power up. The end user could experience high latency in the network because of this."
None of the solutions above worked for me.
In "network Connections" configuration, for my wifi, in "IPv6 settings", I simply selected "Ignore".
Since then, no disconnections. I hope that help others
