I have a wireless dongle and I'm attempting to install their Linux drivers from here.
When I run install.sh (I only have the CLI), I get these errors. How can I get this working? This is a 64bit machine.
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c: In function ârtw_proc_init_oneâ:
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:313:3: error: implicit declaration of function âcreate_proc_entryâ [-Werror=implicit-function-declaration]
rtw_proc=create_proc_entry(rtw_proc_name, S_IFDIR, init_net.proc_net);
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:313:11: warning: assignment makes pointer from integer without a cast [enabled by default]
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:320:3: error: implicit declaration of function âcreate_proc_read_entryâ [-Werror=implicit-function-declaration]
entry = create_proc_read_entry("ver_info", S_IFREG | S_IRUGO, rtw_proc, proc_get_drv_version, dev);
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:320:9: warning: assignment makes pointer from integer without a cast [enabled by default]
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:326:9: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("log_level", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:332:8: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_log_level;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:348:21: warning: assignment makes pointer from integer without a cast [enabled by default]
padapter->dir_dev = create_proc_entry(dev->name,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:379:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("write_reg", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:385:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_write_reg;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:387:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("read_reg", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:393:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_read_reg;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:396:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("fwstate", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:404:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("sec_info", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:412:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("mlmext_state", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:420:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("qos_option", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:427:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("ht_option", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:434:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("rf_info", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:441:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("ap_info", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:448:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("adapter_state", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:455:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("trx_info", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:462:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("mac_reg_dump1", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:469:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("mac_reg_dump2", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:476:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("mac_reg_dump3", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:483:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("bb_reg_dump1", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:490:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("bb_reg_dump2", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:497:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("bb_reg_dump3", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:504:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("rf_reg_dump1", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:511:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("rf_reg_dump2", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:520:9: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("rf_reg_dump3", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:527:9: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("rf_reg_dump4", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:537:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("all_sta_info", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:555:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("best_channel", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:561:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_best_channel;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:564:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("rx_signal", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:570:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_rx_signal;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:572:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("ht_enable", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:578:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_ht_enable;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:580:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("cbw40_enable", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:586:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_cbw40_enable;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:588:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("ampdu_enable", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:594:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_ampdu_enable;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:596:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("rx_stbc", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:602:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_rx_stbc;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:605:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("path_rssi", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:608:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("vid", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:615:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("pid", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:622:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("rssi_disp", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:628:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_rssi_disp;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:631:8: warning: assignment makes pointer from integer without a cast [enabled by default]
entry = create_proc_read_entry("sreset", S_IFREG | S_IRUGO,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:637:7: error: dereferencing pointer to incomplete type
entry->write_proc = proc_set_sreset;
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c: At top level:
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:999:2: warning: initialization from incompatible pointer type [enabled by default]
.ndo_select_queue = rtw_select_queue,
/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.c:999:2: warning: (near initialization for ârtw_netdev_ops.ndo_select_queueâ) [enabled by default]
cc1: some warnings being treated as errors
make[2]: *** [/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911/os_dep/linux/os_intfs.o] Error 1
make[1]: *** [_module_/home/zeno/RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911/driver/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-3.13.0-32-generic'
make: *** [modules] Error 2
Compile make driver error: 2
Please check error Mesg
Or is there a .deb package I can get somewhere?
