I'm trying to increase open file limit in Ubuntu 8.04.4 LTS. Followed information posted in this question: How do I increase the open files limit for a non-root user?
  • Added to /etc/sysctl.conf following line: fs.file-max=500000
  • Added to /etc/security/limits.conf following lines:
    * soft nofile 10000
    * hard nofile 10000
  • Added to /etc/pam.d/common-session (My system do not have any other files prefixed with common-session at /etc/pam.d/) following line: session required pam_limits.so
  • Did system restart
But the value of open file limit is still same 1024:
# ulimit -n
1024
# cat /proc/{PID}/limits
Limit                     Soft Limit           Hard Limit           Units
Max open files            1024                 1024                 files
# cat /proc/sys/fs/file-max
500000
# sysctl fs.file-max
fs.file-max = 500000
What I'm doing wrong and how to increase open file limit?
Index
  • 275
You can increase the maximum number of open files by setting a new value in kernel variable /proc/sys/fs/file-max as follows (login as the root):
sysctl -w fs.file-max=500000
Above command forces the limit to 500000 files. You need to edit /etc/sysctl.conf file and put following line so that after reboot the setting will remain as it is:
vi /etc/sysctl.conf
Append a config directive as follows:
Save and close the file.
Users need to log out and log back in again to changes take effect or just type the following command:
sysctl -p
Verify your settings with command:
OR
sysctl fs.file-max
Source
LnxSlck
  • 12,456
