19
Many people claim that it is impossible to install Ubuntu onto RAID 1 with the Desktop CD. Is this really true? If not, how can it be done?
Sunday
  • 803
Edit: This guide does not take UEFI boot into account. Additional or different steps may be required if UEFI boot is desired. This guide assumes legacy boot!
It is true, that the ubiquity installer does not know about mdadm software raid devices. Also it is true, that the live-cd is missing the mdadm raid administration tool. However, doing some work by hand, it is very much possible to install Ubuntu on RAID1.
In the following I will assume two identical hard disks (/dev/sd[ab]) which will be used completely for our new install. To simplify the recovery if one drive fails, there will be only one mdadm-volume /dev/md0 which will then be partitioned for /, swap and data storage, e.g. /home.
After booting up the live-cd and (if necessary) configuring network access, open up a terminal and assume root access sudo -s
apt-get install mdadm
Now we create a single primary partition each of /dev/sda and /dev/sdb from sector 2048 to the end of the disk, for example using sudo fdisk. I also like to already set the partition type to fd for linux raid autodetection. The keystroke-sequence in fdisk (if the disk is emptyin the beginning, meaning no partitions) is n <return> p <return> 1 <return> 2048 <return> <return> t <return> fd <return> w <return>.
Now we create the mdadm volume:
mdadm --create /dev/md0 --bitmap=internal --level=1 -n 2 /dev/sd[ab]1
I noticed, that the ubiquity installer also does not quite manage to create partitions inside this /dev/md0, so I also did this by hand - again using fdisk. So on /dev/md0 create the following partitions:
  • /dev/md0p1 for your root filesystem, the size of course depending upon how much software you are going to install.
  • /dev/md0p2 for swap, the size of course also depending on what you use the machine for and how much ram it's got
  • /dev/md0p3 for /home, all the space that's left
After that we can begin the Installation. Make sure to start the installer from the terminal with the -b option, because installing the bootloader will fail anyway:
ubiquity -b
Make sure to go for manual partitioning and "use" the 3 partitions you just created and tick the format checkbox for / and /home so a filesystem will be created.
After the installation the system is not yet bootable, so do not restart the box right away. We need to chroot into the installed system and fixup some stuff:
sudo -s
mount /dev/md0p1 /mnt
mount -o bind /dev /mnt/dev
mount -o bind /dev/pts /mnt/dev/pts
mount -o bind /sys /mnt/sys
mount -o bind /proc /mnt/proc
cat /etc/resolv.conf >> /mnt/etc/resolv.conf
chroot /mnt
nano /etc/grub.d/10_linux  # change quick_boot to 0
grub-install /dev/sda
grub-install /dev/sdb
update-grub
exit
Now the newly installed system is ready to boot. Have fun!
Sunday
  • 803
Do not install Ubuntu Desktop CD with RAID 1. My advice:
  1. Use the Ubuntu Server CD to have a guided RAID 1 install. The manual for this is here (ignore the LVM part, not needed) :
    https://help.ubuntu.com/lts/serverguide/advanced-installation.html
  2. After that install the Ubuntu desktop environment with
    sudo apt-get install ubuntu-desktop
  3. Reboot and you have a Ubuntu desktop (installed with the server cd).
-1
I haven't tried, but just came accross http://www.salamander-linux.com/.
Salamander is a modified version of the default installer for Ubuntu Linux, Ubiquity. This modified installer allows users to easily install Ubuntu Linux onto a Software RAID array. No special hardware is required -- the Salamander installer can be used on any system with multiple hard disks.
umpirsky
  • 3,852
