When using a dark theme, the object browser uses white background. Is there some way to change this? This question has been asked a few times, but no answer still.
The theme I am using is E17.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
I also use a dark theme and have the same problem. This is fairly easy to solve though:
  1. If the Server connection is open, close it (right click -> Disconnect server)
  2. Right click on the Server connection and choose Properties...
  3. In the Properties tab click the button in the the second to last item, named Colour
  4. Select a new colour, say #3C3B37
  5. Restart pgAdmin
You have to repeat the procedure for each and every Server connection, but it works.
