This is a very popular question, but bear with me as I have tried everything you are all about to suggest. So this is what I get:
sudo apt-get install ubuntu-desktop
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
ubuntu-desktop : Depends: ubuntu-session but it is not going to be installed
Depends: unity-control-center but it is not going to be installed
Depends: unity-settings-daemon but it is not going to be installed
Recommends: xul-ext-webaccounts but it is not going to be installed
So I try to install unity-control-center
So I try to install unity-settings-daemon
Depends: gnome-settings-daemon-schemas (< 3.10) but 3.12.2-0ubuntu1~trusty2 is to be installed
The root problem appears to be that gnome-settings-daemon-schemas version 3.10 or less is needed, but it can't get it for some reason.
So you might be thinking try the following:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get clean
sudo apt-get autoclean
sudo dpkg --configure -a
sudo -f
I am logged into gnome, when I try to boot into lightgdm the system hangs right after something about printer spooling.
I currently have gdm, kdm and lightgdm.
I want my computer back to just gnome and ubuntu unity. Any thoughts? (A re-install is out of the question)
