-1
So when I try to log into the admin account i go right back to the log-in screen. And I've been searching around all over the internet trying to fix it, but then some other problems always comes along, how may I fix it?
The administrative user in Unix systems is 'root'. It is safest if you log in as an ordinary user and use the sudo command from the terminal to run commands with root privileges. That way, you are less able to accidentally damage your system. Unlike Windows, Unix commands really are normally run as an ordinary user, and some commands even refuse to run if you are root.
Usually, Ctrl+Alt+T will start a terminal. In the terminal, pre-pend your administrative command with sudo, for example sudo apt-get upgrade. If you have a long sequence of commands to run as root, you can use sudo bash -login to run a login shell. Then you no longer need to put sudo in front of each command. Type exit or hit Ctrl+D to leave the root-enabled shell.
Frank M
  • 316
