I am a newbie, so my apologies up front.
I am trying to get DansGuardian installed (which I believe I have) and working. To get it working I need to filter IP traffic through the app via iptables. There are appropriate commands in the 'Getting DansGuardian working on Ubuntu' page. My issue is that the system is telling me that iptables is not currently installed - which is wrong. I understand that it is the primary firewall service for Ubuntu.
I have tried:
xyzzy@ubuntu:/usr/sbin$ iptables
The program 'iptables' is currently not installed.
You can install it by typing:
sudo apt-get install iptables
So:
Reading package lists... Done
Building dependency tree
iptables is already the newest version.
The following package was automatically installed and is no longer required:
  thunderbird-globalmenu
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 342 not upgraded.
Only to be told that the version I am running is the latest.
ufw is running.
Alaa Ali
  • 32,213
Credit to kraxor's comment on the original question:
You should try reinstalling iptables by executing the following command:
sudo apt-get --reinstall install iptables
Alaa Ali
  • 32,213
try these one by one
sudo apt-get remove iptables
sudo apt-get update
it should work now.
OverCoder
  • 490
Use following command:
sudo apt-get update
sudo apt-get install iptables-persistent
and it will install the iptables-persistent package for you.
Fabby
  • 35,017
