Ubuntu Server 14.04 LTS for Azure does not come with Java pre-installed.
The server architecture is AMD64.
I know that you cannot install both the x64 and x86 JREs side-by-side, and I only need the x86 version (application requirements, memory requirements, etc).
Both the x86 and x64 versions of OpenJDK-7-JRE are available directly from Ubuntu here:
http://packages.ubuntu.com/trusty/openjdk-7-jre
http://packages.ubuntu.com/trusty/i386/openjdk-7-jre/download
However, Ubuntu strongly recommends using a package manager (such as apt) to install the package, rather than downloading the binaries using a web-browser and manually copying to the destination machine.
Therefore, I've been trying to install from the command line, but I'm running into issues:
MyAdmin@Server01:~$ sudo apt-get install openjdk-7-jre:i386
Reading package lists... Done
Building dependency tree
E: Unable to locate package openjdk-7-jre
MyAdmin@Server01:~$
The installation is successful if I omit the i386, but then I get the 64-bit JRE by default - which is not what I need.
I've confirmed that the source is already added in /etc/apt/sources.list
deb http://security.ubuntu.com/ubuntu trusty-security main
deb-src http://security.ubuntu.com/ubuntu trusty-security main
deb http://security.ubuntu.com/ubuntu trusty-security universe
deb-src http://security.ubuntu.com/ubuntu trusty-security universe
# deb http://security.ubuntu.com/ubuntu trusty-security multiverse
# deb-src http://security.ubuntu.com/ubuntu trusty-security multiverse
Is there another package, library, or repository that I need to install or update, before I can proceed with the apt installation of the OpenJDK x86 JRE?
Giffyguy
  • 241
It turns out I needed to explicitly add support for 32-bit architecture to the system.
openjdk-7-jre:i386 installed successfully after I did this:
sudo dpkg --add-architecture i386
sudo apt-get update
NOTE: ia32-libs and any other necessary prerequisites are automatically selected and installed when you install openjdk-7-jre:i386. There's no need to install ia32-libs manually, and it's best to install the automatically selected libraries to ensure you definitely get the right version etc.
Giffyguy
  • 241
