-5
After installing Ubuntu I tried to install Windows 7 from a live USB and in booting this appeared:
Windows Boot Manager
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:   1. Insert your Windows installation disc and restart your computer.   2. Choose your language settings, and then click "Next."   3. Click "repair your computer." If you don't have this disc, contact your system administrator or computer manufacturer for assistance.   File: \Boot\BCD   Status: 0xc0000098   Info: The Windows Boot Configuration Data does not contain a valid OS entry.
karel
  • 122,292
  • 133
  • 301
  • 332
The problem shouldn't be having ubuntu installed yet. However you might run into problems booting your ubuntu if you install windows afterwards.
My suggestion because it sound as if you just installed both systems: Try again, installing windows first, ubuntu later
You can follow this guide, below the recommended way to do it there is also explained, what to do if you want to keep your ubuntu installation.
