I have updated my system and I want to do some tests needed to remove the cache. I know the command download the packages list from the repositories,but where is the local database to store this infomation.
Asked
Active
Viewed 726 times
Complete List of files used by apt-get (From man apt-get):
FILES
/etc/apt/sources.list
Locations to fetch packages from. Configuration Item: Dir::Etc::SourceList.
/etc/apt/sources.list.d/
File fragments for locations to fetch packages from. Configuration Item: Dir::Etc::SourceParts.
/etc/apt/apt.conf
APT configuration file. Configuration Item: Dir::Etc::Main.
/etc/apt/apt.conf.d/
APT configuration file fragments. Configuration Item: Dir::Etc::Parts.
/etc/apt/preferences
Version preferences file. This is where you would specify "pinning", i.e. a preference to get certain packages from a
separate source or from a different version of a distribution. Configuration Item: Dir::Etc::Preferences.
/etc/apt/preferences.d/
File fragments for the version preferences. Configuration Item: Dir::Etc::PreferencesParts.
/var/cache/apt/archives/
Storage area for retrieved package files. Configuration Item: Dir::Cache::Archives.
/var/cache/apt/archives/partial/
Storage area for package files in transit. Configuration Item: Dir::Cache::Archives (partial will be implicitly
appended)
/var/lib/apt/lists/
Storage area for state information for each package resource specified in sources.list(5) Configuration Item:
Dir::State::Lists.
/var/lib/apt/lists/partial/
Storage area for state information in transit. Configuration Item: Dir::State::Lists (partial will be implicitly
appended)
In case of sudo apt-get update, following may help you:
/etc/apt/sources.list/etc/apt/sources.listd//var/lib/apt/lists//var/lib/apt/lists/partial/
Pandya
- 37,289
From man apt-get:
clean clean clears out the local repository of retrieved package files. It removes everything but the lock file from /var/cache/apt/archives/ and /var/cache/apt/archives/partial/.
So, to clear the cache:
sudo apt-get clean
chili555
- 61,330
