I'm having an issue trying to install Ubuntu 14.04.
When booting up the CD, I select "Install Ubuntu" which is fine, however the problem occurs each time I arrive at the "where are you?" screen when choosing your geographic location.
I select my location and I always get a pop-up with the following error message: ??? ???
Literally, that is all it shows! I've tried installing using a USB stick too and the same thing occurs at the same bit. It also happens on 13.10 as well.
Eachtime i select OK on the error message, I am taking back to the start of the installation again.
Any ideas?
I am using a HP Microserver N40L.
/var/log/installer/debug
Exception caught in process_line:
Traceback (most recent call last):
  File "/usr/lib/ubiquity/ubiquity/filteredcommand.py", line 145, in process_line
    return self.dbfilter.process_line()
  File "/usr/lib/ubiquity/ubiquity/debconffilter.py", line 430, in process_line
    data = self.db.command(command, *params)
  File "/usr/lib/python3/dist-packages/debconf.py", line 66, in command
    self.write.write("%s %s\n" % (command, ' '.join(map(str, params))))
ValueError: I/O operation on closed file.
/var/log/syslog
/dev/mapper/pdc_eajbihdagf errors
Jul 29 10:58:30 ubuntu activate-dmraid: Enabling dmraid support.
Jul 29 10:58:30 ubuntu dmraid-activate: ERROR: Cannot retrieve RAID set information for pdc_eajbihdagf
Jul 29 10:58:31 ubuntu kernel: [   87.667498] xor: measuring software checksum speed
Jul 29 10:58:31 ubuntu kernel: [   87.706052]    prefetch64-sse:  6157.000 MB/sec
Jul 29 10:58:31 ubuntu kernel: [   87.746058]    generic_sse:  5808.000 MB/sec
Jul 29 10:58:31 ubuntu kernel: [   87.746062] xor: using function: prefetch64-sse (6157.000 MB/sec)
Jul 29 10:58:31 ubuntu kernel: [   87.834089] raid6: sse2x1    2173 MB/s
Jul 29 10:58:31 ubuntu kernel: [   87.902132] raid6: sse2x2    3197 MB/s
Jul 29 10:58:31 ubuntu kernel: [   87.970134] raid6: sse2x4    4002 MB/s
Jul 29 10:58:31 ubuntu kernel: [   87.970138] raid6: using algorithm sse2x4 (4002 MB/s)
Jul 29 10:58:31 ubuntu kernel: [   87.970141] raid6: using intx1 recovery algorithm
Jul 29 10:58:31 ubuntu kernel: [   88.023211] bio: create slab <bio-3> at 3
Jul 29 10:58:31 ubuntu kernel: [   88.023698] Btrfs loaded
Jul 29 10:58:31 ubuntu kernel: [   88.093940] JFS: nTxBlock = 8192, nTxLock = 65536
Jul 29 10:58:31 ubuntu kernel: [   88.171643] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
Jul 29 10:58:31 ubuntu partman:   No matching physical volumes found
Jul 29 10:58:31 ubuntu partman:   Reading all physical volumes.  This may take a while...
Jul 29 10:58:31 ubuntu partman:   No volume groups found
Jul 29 10:58:31 ubuntu partman-lvm:   No volume groups found
Jul 29 10:58:34 ubuntu ubiquity: tune2fs: Bad magic number in super-block while trying to open /dev/mapper/pdc_eajbihdagf
Jul 29 10:58:34 ubuntu ubiquity: Couldn't find valid filesystem superblock.
Jul 29 10:58:34 ubuntu partman: Error running 'tune2fs -l /dev/mapper/pdc_eajbihdagf'
ubiquity errors
Jul 29 12:04:19 ubuntu ubiquity[10648]: switched to page timezone
Jul 29 12:04:20 ubuntu ubiquity[10648]: Geoname lookup for "New York" failed: 2 Cannot resolve hostname (geoname-lookup.ubuntu.com)
Jul 29 12:04:25 ubuntu ubiquity[10648]: Geoname lookup for "London" failed: 2 Cannot resolve hostname (geoname-lookup.ubuntu.com)
other errors
Jul 29 14:59:22 ubuntu kernel: [  616.983294] SQUASHFS error: Unable to read fragment cache entry [26f79ee9]
Jul 29 14:59:22 ubuntu kernel: [  616.983297] SQUASHFS error: Unable to read page, block 26f79ee9, size cf29
Jul 29 14:59:22 ubuntu kernel: [  616.983302] SQUASHFS error: Unable to read fragment cache entry [26f79ee9]
Jul 29 14:59:22 ubuntu kernel: [  616.983305] SQUASHFS error: Unable to read page, block 26f79ee9, size cf29
Jul 29 14:59:22 ubuntu kernel: [  616.983309] SQUASHFS error: Unable to read fragment cache entry [26f79ee9]
Jul 29 14:59:22 ubuntu kernel: [  616.983311] SQUASHFS error: Unable to read page, block 26f79ee9, size cf29
Jul 29 14:59:38 ubuntu kernel: [  633.244836] FAT-fs (sdc1): Directory bread(block 15262) failed
Jul 29 14:59:38 ubuntu kernel: [  633.244846] FAT-fs (sdc1): Directory bread(block 15263) failed
Jul 29 14:59:38 ubuntu kernel: [  633.244850] FAT-fs (sdc1): Directory bread(block 15264) failed
karel
  • 122,292
  • 133
  • 301
  • 332
