How can I copy-paste following command:
rm -r ~/.gconf/apps/gnome-terminal
gconftools --recursive-unset /apps/gnome-terminal
into a virtual-terminal?
Pabi
  • 7,429
If you can't use the standard terminal:
...I cannot use the terminal normally ...
start your installed packet manager Synaptic and install an other terminal xterm.
Use Alt+F2 and type xterm and Return
Now you can copy and paste:
  • mark the command with the left mouse button
  • paste the command with the middle mouse button
Alternatively write a short script and start the script in the virtual terminal:
  • Start gedit and add the lines below:
    #!/bin/bash
  • Save the file as foo in your home folder and switch to tty.
  • Login and make the script executable
    chmod +x ~/foo
  • Start the script
    ./foo
A.B.
  • 92,125
As far as I know, there is no way to access a desktop clipboard from a virtual terminal.
The easiest thing to do in this case is to save and run these commands as a script.
Brian Z
  • 712
