I want to have both PHP 5.2.17 and PHP 5.3.5 installed on my Ubuntu machine and switch as per my necessity. How can I achieve this?
You can use a php version manager to achieve this. Different version managers are available like:
- https://github.com/phpbrew/phpbrew
- https://github.com/CHH/phpenv
- https://github.com/wilmoore/php-version
My favorite is phpbrew. Hope this helps.
You can run 2 different PHP versions at once, but it's not as easy as just apt-getting them. You need to run one seperately installed version and serve it up according to the settings in your apache config.
You can do this using fastcgi for example: basically what you are looking for is the config you see on this page. You add a different handler in your config based on the situation/port/domain you need. The trick, after installing both versions, is this step:
===from that page==
- The last step was to create virtual hosts. In the end I have three files in /etc/apache2/sites-enabled: 000-default, php5.3.17 and php5.4.7 With the following contents
default:
<VirtualHost *:80>
ServerName localhost
DocumentRoot /var/www
<Directory "/var/www">
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
AddHandler php-cgi .php
Action php-cgi /php-fcgi/php5317.fcgi
</Directory>
</VirtualHost>
php5.3.17:
<VirtualHost *:80>
ServerName 5317.localhost
AllowOverride All
Order allow,deny
allow from all
</Directory>
</VirtualHost>
php5.4.7:
<VirtualHost *:80>
ServerName 547.localhost
AllowOverride All
Order allow,deny
allow from all
Action php-cgi /php-fcgi/php547.fcgi
</Directory>
</VirtualHost>
See for the complete installation the linked question. Don't forget to look at the two links in the header as well, they look like nice tutorials (but less compressed). This and That
(don't be put of by the fact that the linked question is a big one with no accepted answer. The method should (and does) work fine, but the user forgot to use <?php and used <? with shorttags off, see the comments)
I installed php 5.6 and 7.0 but besides all tips it kept running 5.6, so this command saves the day (in my case i chosse option 1 and restart apache):
sudo update-alternatives --config php
- 250
This one works for me: https://lornajane.net/posts/2016/php-7-0-and-5-6-on-ubuntu
Same as the script from "Growling Flea", but using new versions.
Add the PPA
The PHP 5.6 and PHP 7.0 packages are from a third party PPA, not provided by the official Ubuntu repositories from Canonical. The PPAs I'm recommending here are from Ondřej Surý who packages PHP for Debian (which is then used by Ubuntu) so while it's not an official repository, he's not exactly random! The PPA itself is here
To add the PPA to your setup:
sudo add-apt-repository ppa:ondrej/phpThen we'll also want to grab information about what is on offer from this new PPA, so then run:
sudo apt-get updateInstall new PHP versions
I already had some of the php5 packages installed, but I didn't uninstall anything, I just let apt work out what it wanted to do when I asked it to install the new versions:
sudo apt-get install php5.6 php7.0This resulted in a lot of complaining from apt and lots of conflicts. The first suggested resolution was to remove all the stock php5 packages so that PHP 5.6 could be installed - so I just accepted the first suggestion.
I use apache so this setup gave me apache with both php5.6 and php7.0 modules available, and the php5.6 module actually loaded.
As well as just the PHP itself, all the extensions and other tools you'd expect with PHP are there for both versions of PHP so it's very easy to add in the modules that you need. I was very, very impressed with how nicely this is done.
Configuring and switching versions
Now you have two completely separate versions of PHP installed on your system, so let's have a look at where all the pieces went!
The config files are all in
/etc/php/5.6and/etc/php/7.0respectively - inside here is where you can configure which extensions are loaded, set the ini settings, and everything else for each version in isolation.I'm an apache user, and as I mentioned both modules are available. So to switch from one to the other I need to do:
sudo a2dismod php5.6 sudo a2enmod php7.0 sudo service apache2 restartFor nginx users, the changes are almost as easy, Digital Ocean have good documentation on this (they do have great docs!) so check out their guide: https://www.digitalocean.com/community/tutorials/how-to-upgrade-to-php-7-on-ubuntu-14-04 as it includes a section on reconfiguring nginx to use another version of PHP.
From the command-line, I have both php5.6 and php7.0 available as commands. I also still have a php command - look in /etc/alternatives to see that it symlinks to a particular version of PHP cli*. You can also quickly check which yours is using by running
php -v.* more specifically, run which php to see which version of PHP is being used - but this will probably point to
/usr/bin/php, which for me is itself a symlink to the/etc/alternatives/phpcommand.Working with extensions
This PPA comes with the usual php-pear package which offers the pecl command for both versions of PHP, so any extensions that are available via PECL can be installed in the usual way. You will also need the relevant headers so either php5.6-dev or php7.0-dev should be installed.
When the pecl installation completes, you'll get a note to add the *.so file to your php.ini; in fact the best thing to do here is to look at what's in
/etc/php/mods-available. There will be some modules already here, each in its own file named after the extension and ending in .ini. You can copy one to use as a template or create your own and put all the relevant configuration for the extension in it (as a minimum, you needextension=[extensionName].so).Once the new extension is in mods available, enable and then check it by doing:
sudo phpenmod extension php -mThis will create the symlinks in the right places for your current version of PHP to load this module, and you should see it in the list of modules output by the
php -m. Pro tip: if you don't see it in the output, scroll all the way to the top of the output and see if there are any useful error messages there.
- 122,292
- 133
- 301
- 332
From this post, I just put in order the commands and explain in order as I was served (Ubuntu 12.04)
This method give you:
script with menu, that permit switch between php versions installed (not both at same time)
various PHP versions installed on your server
separated conf files
Install all versions that you need (i have two)
Install dependencies:
sudo apt-get install flex apache2-threaded-dev libxml2-dev apache2 apache2-mpm-prefork apache2-threaded-dev apache2-utils apache2.2-bin apache2.2-common
Install PHP 5.3 first time. Download php sources
md5sum Downloads/php-5.3.10.tar.bz2
mkdir ~/Sources
cd ~Sources/
cp -Rf ../Downloads/php-5.3.10.tar.bz2 .
tar xjf php-5.3.10.tar.bz2
cd php-5.3.10/
sudo mkdir /usr/local/php/php_5.3.10
Install PHP5.6 first time. Download php sources
md5sum Downloads/php-5.6.11.tar.bz2
mkdir ~/Sources
cd ~Sources/
cp -Rf ../Downloads/php-5.6.11.tar.bz2 .
tar xjf php-5.6.11.tar.bz2
cd php-5.6.11/
sudo mkdir /usr/local/php/php-5.6.11
Script manager versions PHP: Create a file called php.sh and put it in /bin/:
#!/bin/bash
opcion=0
cat << CABECERAMENU
Opciones del menu
1 => PHP 5.3.10
2 => PHP 5.6.11
CABECERAMENU
echo -n "Ingrese su eleccion: "
read opcion
echo
case $opcion in
"1")
rm /etc/apache2/php.conf
ln -s /usr/local/php/php_5.3.10.conf /etc/apache2/php.conf
/etc/init.d/apache2 restart
"2")
ln -s /usr/local/php/php_5.6.11.conf /etc/apache2/php.conf
echo "Opcion no valida"
esac
Compile and install php 5.3:
cd ~/Sources/php-5.3.10/
sudo ./configure --prefix=/usr/local/php/php_5.3.10 --with-config-file-path=/usr/local/php/php_5.3.10/lib --with-mysql --with-libdir=/lib/x86_64-linux-gnu --with-apxs2=/usr/bin/apxs2 --enable-zip --with-gd --with-curl --with-xmlrpc --with-freetype-dir=/usr/lib/x86_64-linux-gnu --with-jpeg-dir=/usr/lib/x86_64-linux-gnu --with-pdo-mysql --with-pdo-pgsql --enable-soap
sudo make clean
sudo make
sudo ls -lhart /usr/lib/apache2/modules/libphp5.*
sudo rm -rf /usr/lib/apache2/modules/libphp5.*
sudo make install
sudo rm -rf /usr/local/php/php-5.3.10/modules/libphp5.so
sudo mv /usr/lib/apache2/modules/libphp5.so /usr/local/php/php_5.3.10/modules/
ls -lhart /usr/local/php/php_5.3.10/modules/
sudo a2dismod php5
Compile and install php 5.6
cd ~/Sources/php-5.6.11
sudo ./configure --prefix=/usr/local/php/php_5.6.11 --with-config-file-path=/usr/local/php/php_5.6.11/lib --with-mysql --with-libdir=/lib/x86_64-linux-gnu --with-apxs2=/usr/bin/apxs2 --enable-zip --with-gd --with-curl --with-xmlrpc --enable-calendar --enable-sockets --with-freetype-dir=/usr/lib/x86_64-linux-gnu --with-jpeg-dir=/usr/lib/x86_64-linux-gnu --with-pdo-mysql --with-pdo-pgsql --enable-soap
sudo make clean
sudo make
sudo make install
sudo rm -rf /usr/local/php/php_5.6.11/modules/libphp5.so
sudo mv /usr/lib/apache2/modules/libphp5.so /usr/local/php/php_5.6.11/modules
ls -lhart /usr/local/php/php_5.6.11/modules
sudo a2dismod php5
Let's to use them:
$ sudo php.sh
Opciones del menu
1 => PHP 5.3.10
2 => PHP 5.6.11
Ingrese su eleccion: 1
* Restarting web server apache2 apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
... waiting apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
- 3,376
- 5
- 34
- 52
- 31
Problems:
Single apache instance can not run two different PHP versions simultaneously (at least as far as I know it).
Two different PHP versions can't be installed from packages as those will conflict (and try overwriting the same directories).
Solution:
for b) Compile „the other” PHP version from source, manually (or if you prefer, grab source of appropriate package and modify it to avoid conflicts and to modify install paths)
for a) Create separate set of configs for apache with different module paths and separate startup script. And of course run it on separate port.
- 6,519
- 536
Instead of making multiple VirtualHost I just add the below code in my .htaccess file and surprisingly it worked,
<FilesMatch \.php$>
SetHandler "proxy:unix:/var/run/php/php7.2-fpm.sock|fcgi://localhost/"
</FilesMatch>
Node: I had already installed php7.2-fpm before using the code.
- 739
I had the same problem when I was handling multiple projects. I referred this article But it was like every time I need to switch the versions if need but this gives the flexibility for cli and web separately.
Moving From php5.6 to php7.0
For Apache, we can use the command as:
sudo a2dismod php5.6 ; sudo a2enmod php7.0 ; sudo service apache2 restart
For CLI, we can use the command as:
sudo update-alternatives --set php /usr/bin/php7.0
Moving From php7.0 to php5.6
sudo a2dismod php7.0 ; sudo a2enmod php5.6 ; sudo service apache2 restart
sudo update-alternatives --set php /usr/bin/php5.6
It can be done by disabling and enable the new version of PHP-
- switch to older version -
a2dismod php7.0
service apache2 restart- switch to newer version
a2enmod php7.0
- 101
You can also run each website with diferentes users. More secure.
I used this aproach one time.
http://blog.servergrove.com/2011/08/22/how-to-setup-multiple-php-versions-on-apache/
Now i think it is better to use php-fpm... but it is a litle more complicated to configure multiple php versions.
Will need to run multiples php-fpms and set apache to use each other.
- 6,519
If you want to run them at the same time, you need two different ports. Maybe you can just change your apache config (httpd.conf) with a simple script that moves one or another version into the correct position before starting apache.
- 8,436
I wrote a bash script that allows me to easily switch between installed php versions on my box. I run several virtual hosts because I have several web projects with customers that have old and new programs. Some of these projects require older versions of php and other projects require php7.0.
Read through my comments and make sure you understand what is going on before using this.
#!/bin/bash
# This file is for switching php versions.
# To run this file you must use bash, not sh
# OS: Ubuntu 14.04 but should work on any linux
# Example: bash phpswitch.sh 7.0
# Written by Daniel Pflieger
# growlingflea at g mail dot com
NEWVERSION=$1 #this is the git directory target
#get the active php enabled mod by getting the array of files and store
#it to a variable
VAR=$(ls /etc/apache2/mods-enabled/php*)
#parse the returned variables and get the version of php that is active.
IFS=' ' read -r -a array <<< "$VAR"
array[0]=${array[0]#*php}
array[0]=${array[0]%.conf}
#confirm that the newversion veriable isn't empty.. if it is tell user
#current version and exit
if [ "$NEWVERSION" = "" ]; then
echo current version is ${array[0]}. To change version please use argument
exit 1
fi
OLDVERSION=${array[0]}
#confirm to the user this is what they want to do
echo "Update php" ${OLDVERSION} to ${NEWVERSION}
#give the user the opportunity to use CTRL-C to exit ot just hit return
read x
#call a2dismod function: this deactivate the current php version
sudo a2dismod php${OLDVERSION}
#call the a2enmod version. This enables the new mode
sudo a2enmod php${NEWVERSION}
echo "Restart service??"
read x
#restart apache
- 207,228
- 21
- 4
