I don't have alot of experience in linux, I tried all the solution I could find before asking this, here it goes:
I recently got a new Toshiba laptop, today I installed ubuntu 14.04LTS alongside of windows 7, and it completed successfully, then I encoutered the following:
1- The resolution was low (640X480), couldn't change it from settings->display, it's the only option.
2- I installed the nvidia driver by running sudo apt-get install nvidia-current, then rebooted, grub menu appear, then just a blank screen appear and it hang on it.
3- Went into root shell and uninstalled it by running apt-get remove nvidia-current, uninstalled ok, restarted, encountered the same problem, only a login in command-line appear and when I try to login it goes to a blank screen again.
4- Again went into root shell and ran dpkg-reconfigure xserver-xorg. Just excuted the command and nothing appeared, still have the same problem.
5- Reinstalled ubuntu using livestick, went back to low resolution, opened settings->software & updates->Additional drivers and I found out that it's using xserver-xorg-video-nouveau which only have low resolution.
6- Installed the nvidia-331 binary, rebooted, had the same blank screen.
which driver should I install?
